As with much to do with the iPhone, there's a bit of a trick to
getting this working smoothly so you can have control over your iPhone
music, while keeping it as darn easy to work with as possible. The
answer?
Create a custom playlist for your iPhone music library.
Let me show you how to do it - it's pretty darn easy.
Pop into iTunes and choose
File -->
New Playlist. Now rename it to something logical: I use "iPhone Sync":
Now you can just drag and drop music from your iTunes library (in
iTunes, needless to say) into this new playlist. When you're ready,
you'll see a bunch of music happily ensconced in the playlist (remember,
it's all just "pointers": the actual music files are still safely in
the main music library, so if you delete something from a playlist , you
haven't deleted the original music file itself):
At the bottom of the iTunes window it shows you how
many songs are in the playlist, along with the size and total playing
time.
At this point, you need to plug in your iPhone if you haven't already done so. It'll pop up the usual summary screen:
Now click on the "Music" tab and you'll see that you can select "sync
playlist". Do that, then select the new iPhone sync playlist you've
created
Set things up and that's all there is to it. Now
click "Sync" in iTunes and it'll synchronize your playlist with the
iPhone music library and next time you click on that ole' "iPod" button
on the iPhone, your selections from you music library will be present.
Oh, and one really nice feature of creating this playlist is that you
can manage it, adding and deleting songs to your heart's desire, even
without your iPhone present. Whatever changes you make are instantly
applied to your iPhone music library the very next time you synchronize
the device. Suddenly even 8GB might feel small. :-)
Regards
Yes, the same happened to my hdd070 - after music transfer via musicmatch ( the only way).. it says it's empy.. have tried so reinstall , reformatting, reset, .. many times.. can you help me ? thanks a lot !
yes i have same this problem i have music data but i cant see only one messege show screen connect to computer so please help me
