Question about LG DLE2514 Electric Dryer
Maximum power draw
Need to know how many watts the LG DLE2514 dryer uses on high.
  • rsdcoop Nov 20, 2008
    Thanks for looking for manual. Can't check machine tag (don't own one yet). I need this info to decide whether I can squeak thru with my current wiring.
  • 24 Answers
Should have a name plate that lists the wattage or amperage.
Typically Dryers have 4000 to 5000 watt elements and have to be fused at 30 Amp. (Or breaker must be 30A)
Motor is much less current or wattage. The element uses the lion's share of power.
I looked for a manual but LG doesn't have one available.
Posted on Nov 20, 2008
  • Gary C Smith
    Gary C Smith Nov 21, 2008
    OK
    Lets talk about your power supply, etc.
    1) Do you currently have an outlet for a dryer?
    2) Do you have an electric range? Water heater?
    3) Do you know the size of your electric service?
    Also, do you have fuses? Breakers?
    Either way, are there spare circuits available?
    I will have more with answers.
    Gary
Where the time usually is displayed it says " CL"
Hi
Assuming it as LG DLE2514 Electric Dryer CL means the Child Lock has been activated to avoid any harm to the children. To reset the dryer you'll need to press and hold dry level for 5 seconds. Hope this helps...please post back for further assistance.
Daniel
Feb 24, 2011 | LG DLE2514 Electric Dryer
Why would my new 1500 watt inverter readout show overload 13.8 volts entering
It would show overload if you're drawing more power than it can supply. 1500 Watts is a very high output for an inverter but that is the maximum it's capable of. As with any electrical supply you should not draw the maximum power it's capable of as this can cause it to burn out. Around 1200 would be the max you should draw continuously. You need to check the power requirements of whatever you're running on it. Also you need to check that it's capable of taking 13.8 volts. If 12 volts is the recommended input, putting in 13.8 will increase the voltage output which could damage appliances being run on it.
Jan 10, 2011 | PowerBright New 1500 Watt 12V DC to AC...
MY LG IS NOT POWER UP I DON'T KNOW WHERE I CAN FOUND THE LIGHT FLICKER
You have a power issue and may need a qualified electrician to resolve it.
Good luck
Sep 18, 2010 | LG DLE2514 Electric Dryer
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Dryer is not drying efficently
The heating element needs to be replaced. It can be done from accessing in the back of the machine.
Sep 17, 2009 | LG DLE2514 Electric Dryer
WILL NOT POWER UP
You have an issue with the control board and it will need to be addressed by a qualified LG technician.
Nov 28, 2007 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
152 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
