Question about Kitchen Ranges
Tappan Gas Range Model TGF316 has flames that come into oven
Just installed a new tappan range in our country home this weekend and whenever we turn on the oven, the flames shoot thru the vents on the bottom panel and into the oven. Is this the norm? Yes, we installed the orifices for the LP gas that we use (not the orifices for the natural)
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
docjohn174
  • 943 Answers
SOURCE: I want to convert a tappan stove to lp gas.
hi thanks for the question the brass fitting at the burner unscrews to change from natural gas to lp if its screwed in all the way back that off till you get a nice blue flame do it to all burners thanks the appliance doc
Posted on Sep 25, 2008
duby1990
  • 370 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Tappan gas range oven makes a whisling sound
the gas pressure regulator can whistle sometimes. turn up the radio. (just kidding) I have had some new units that did this and replaced the regulator and it still did it! I was working as factory authorized service tech and my factory techline said it was a gas pressure thing. I was thinking it was the valve rather than regulator but tech guys said no. I don't know about that response but thats what I got.
May 08, 2008 | Tappan TGF657 Gas Kitchen Range
Oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Conversion help
you need to unscrew the orifice until the flame stops yellow tipping meaning you have very little yellow at the tip of the flame
Dec 17, 2007 | Tappan MPF500PBW Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan gas oven
This is usually caused by the volume of gas expelled during the lighting process, ie bofore the flame has established, it should be nothing to worry about but check it ignights quickly to resolve problem. Regards Engineer
Jan 02, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
173 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
