Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Side by side frig
Water in front of freezer side spoaradically
  • anngoldb Nov 21, 2008
    so far it seems to have fixed the sporadic leak, thanks!!!
    Champion:
  • 210 Answers
You need to defrost and clear the drain in freezer.
Posted on Nov 19, 2008
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water in floor
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 26, 2008 | Refrigerators
Frig side by side problem
I rolled the frig forward enough so I could unplug the power cord from the outlet. Then
I removed the freezer back panel and found the evaporator coils completely encased in frost. I used hot water in a 20 ounce sqeezable water bottle to remove the caked frost from the coils. I used the back panel as a chute to route the water into a large square bucket I placed on the floor right in front of the freezer. I then disconnected the defrost heater and checked continuity with my meter on the Rx1 scale. Meter needle did not move when connected across the heater indicating that the heater was bad. Called the local parts supplier and gave them the numbers off the old part. They had it in stock for $27.31 so went and picked it up, plugged it in, put in the mounting screws, replaced the freezer back panel, and plugged the frig in. I turned both the freezer and frig thermostats to their normal position. Four hours after my better half got all the food back in the freezer and the frig, the temperature in the refrigerator was 36 degrees.
Feb 28, 2008 | GE GSH25JFR Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
