Question about Brother MFC-665CW All-In-One InkJet Printer
Brother MFC-665CW - won't print anything
The Yellow cartridge on my printer indicates "empty."  I need to print something and it doesn't matter if it's B&W.  I disabled "color printing" on the computer, but the printer still refuses to print ANYTHING.  Do all cartridges need to be full even if I'm only printing in B&W?
  • 26 Answers
SOURCE: Brother MFC-420CN color ink empty but want to print/copy in B&W
brother won't print od do anything is one of the 4 inks are empty so first of all you have to replace whatever is empty, when you remove it it will ask you if you changed it and if it is a new one you will press 1 twice per cartridge, if you put compatible ink in you will clog the ink head up and then be stuffed
Posted on Dec 15, 2007
  • 30 Answers
SOURCE: Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Posted on Feb 06, 2008
Mix-it-up
  • 832 Answers
SOURCE: Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 11, 2008
eagle338
  • 4889 Answers
SOURCE: MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Posted on Jun 11, 2009
komguy
  • 2306 Answers
SOURCE: How do I clear
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Posted on Oct 02, 2009
Not printing black when a color cartridge is empty
i don't own this printer, but most printers use all colors to print black unless you specifically say in the printer options, only print black....also a lot of printers now a days only print when all cartridges have ink....makes you buy.
Jan 09, 2010 | Brother Multi-Function Center MFC-665CW...
Want to set brother 665CW to print black and white
It can be done, but all ink cartridge need to be in printer.The printer need all cartridges to initialized.When you start printing something click on Properties then find Advanced.There is a option Colour/Greyscale.Check on greyscale and it's done.
Oct 28, 2009 | Brother MFC-665CW All-In-One InkJet...
"Ink level Yellow Low"
where the cartridge sits in the machine, you will see a sensor that reads the cartridge ink level, either the sensor is dirty or needs to replaced, and did you try an new Brother cartridge?
Jun 06, 2009 | Brother MFC-665CW All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Yellow will not print
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 22, 2008 | Brother Multi-Function Center MFC-665CW...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Operating problem as described below
unplug mfc from power outlet. take all carts out and leave scanner open. wait a minute. replug to power. wait until machine demands carts. insert one after another and ANSWER display! Close cover.
NEVER change cart until mfc stopps printing (near empty is a reminder to buy new ones :-))
Jun 18, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-665CW All-In-One InkJet Printer Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
