Question about Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer
Dewalt dc618 nailer is not firing
My nailer is about two years old,but does not seem to be firing,the battery is good because the gun loads up but dosnt fire .what could cause this problem
  • Anonymous Mar 17, 2009
    I have the same problem but mine was imported brand new from America via a postal address i had to set up. The problem with mine is it fires but most ov the time doesnt fire a nail the pin misses the nail then stays out? Must be a fault with the lining up ov the nails? The touble is i can send it back now as Dewalt dont ship direct to uk.
  • TechTrainer May 11, 2010
    so when you plug in the battery does the headlight come on and remain steady (no flashing) and the motor run but the tool wont actuate?
    also, check the driver blade to see if it's down or up
    Novelist:
  • 144 Answers
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Posted on Jun 26, 2009
  • William Robinson
    William Robinson Jul 14, 2010
    I hope I answered your question. I assumed you checked to see if there was a nail jambed in the nose peice. If there was the motor won't run and the lights will just flash. If the motor does run and no fire then my answer should help.
  • Scott Clarke Aug 05, 2010
    I am having a little different problem, first it has not been used very much and I have not tryied until now to fix it. the unit is a Reconditioned one.
    there appears to be no jamming or bent rod. I have the face off and the bands look good.
    I pull the trigger and the light stays on for 10 sec. with no blinking
    When I depress the nose the light blinks once and a gear moves ever so slightly, the one with the 2 bands.
    No fan turns on just the blink light and tiny **** movement.
Have you put any oil or wd40 into the gun. i did this just to clean the gun up a bit and ruined. went to get it fixed and they said these machines run on friction so any lubricant is a no no. do not rty and maintain these guns with any lubricants. cost was about $300 to fix so i just got another one.
Posted on Feb 19, 2010
  • Vhuynh Jan 30, 2011
    Cleaned the groves in the flywheel and the tangental rod with alchol followed by and an air blow and you will good to go.
If your dc618 fires sometimes but other times fires weak or not at all then try replacing the spring. That controls the roller just under front cover.
Posted on Aug 02, 2018
    Problem Solver:
  • 4 Answers
Make sure the lock out\safety is not engaged
dewalt dc618 nailer is not firing - /uploads/images/6_23_2014_6_34_25_pm.jpg
Posted on Jun 23, 2014
If there is a nail jambed between the firing pin and nailers that would do it If you've already checked that try oiling it or the firing pin it'self could be broken. Also most (not all) of the battery operated nail guns require an air cartrige to force the firing pin down I don't know about the dewalts because paslode is my brand but it is very small and sometimes it is hard to find.
Posted on Dec 03, 2008
  • ccsinc2501
    ccsinc2501 Aug 18, 2013
    I have a DC618 about two months old . It will actuate but will not fire ? Any ideas I am thinking of taking back to where I bought it.
N88rh bostitch nailer fires first shot without trigger depressing
Worn orings in the gun and the trigger valve will cause the gun to fire upon connecting the air. It is a good practice to remove the nails when you remove the airline until you can replace the trigger valve. I believe that you gun uses a TVA6 valve. It should be replaced when it begins to leak or if the trigger pin seems loose and rocks from side to side. Factory valve costs about 25 dollars and aftermarket sells for about 12 to 18 dollars. Good luck
Jan 20, 2014 | Stanley Bostitch 28 Industrial Framing...
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Nov 11, 2012 | Dewalt DC616kn 18 - volt 16 - gauge...
Www.dewalt.com
Worn trigger valve orings will cause gun to fire twice, and /or attempting to single fire nail with bump-fire trigger. Easy test, look closely at firing pin under trigger. It should fit snuggly an not move from side to side in valve. If loose, replace valve. If your nailer has bump-fire trigger, do no attempt to place gun then fire one shot because the gun will most likely double fire. Good luck.
Oct 09, 2012 | Porter Cable Coil Roofing Nailer
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I changed the feeder springs in my hitachi NV83 a2 and it wants to double fire and jaming up the driver with seconded nail. it was skip nailing before i changed springs. any help you could give me would be...
Your nailer is a very heavy duty nailer with very powerful blow. Works best with full size nails, not 2 inch range that are used in fencing, they are not spaced correctly for your gun (like hitting number 6 nail with sledge hammer). Open side door and remove the nails, leave the door open and dry fire gun against piece of rubber or old coiled air hose. The driver should return all the way up between shots and the feeder should move back then forward just as fast as the driver moves. If the feeder seems to move in slower motion then pull feed piston and replace orings and remove debris from feed cylinder. If the driver seems to stick out further than normal then lower bumper could be breaking up causing debris to enter feeder. Make sure that the driver is not bent and has a squared bottom, if rounded, remove and grind square. Finally adjust the depth control up or down slightly and bump fire for test, do not place gun on the work then fire. good luck
Jun 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer Logo
10,731 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
