Question about Bernina Virtuosa 160
The needle thread will not pick up the bobbin thread
Everything looks right -- I have rethreaded the machine and rewound the bobbin several times and changed the needle. I took it apart and cleaned an oiled it, but still the top thread will not pick up the bobbin thread.
My machine is a Bernina 1260 -- not listed in the product list.
  • sherri59tkd Apr 29, 2009
    I was sewing and her a noise as if my needle broke but it hadn't. The needle was stuck in a down position so I took it apart, cleaned, oiled and now I can't get the needle thread to pick up the bobbin thread. I've rethread and checked everything over and over to no avail. Another thing is that the little piece that holds the needle keeps falling off???
    Have you found a solution yet? I have the same machine, Bernina 1260
  • Anonymous Mar 17, 2014
    was doing an embroidery pattern, and on final color, the machine jammed. Took apart, cleaned, put on new needle and rethreaded machine. Would not pick up the bottom thread. Measage said the top thread was broke, but it wasn't ??
    Problem Solver:
  • 23 Answers
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Posted on Nov 19, 2008
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Will not sew,looks like its sewing but can pull right out. have changed needle, rethread,checked tension, not changed bobbin tention got any ideas
the needle thread is not picking up the bobbin thread
could be a case of needle /hook timing, not pulling the bobbin thread down the slot in the bobbin case to under the spring
Take it to a sewing machine repair shop for a service
Jan 05, 2016 | Sewing Machines
Why won't it pick up bobbin thread
Try changing the needle--make sure the needle is inserted correctly
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 11, 2014 | Sewing Machines
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
Threading the bobbin thread
try rethreading the machine top and bobbin--make sure to use every
thread guide
try changing the needle--make sure the needle is turned the right way
and inserted correctly into the needle holder
make sure the bobbin is turned the right way in the bobbin case
and if the machine still will not pick up the bobbin thread it would be a
good idea to have the machine checked to see if the timing is ok.
here is a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Nov 06, 2012 | Singer 7258 Sewing Machine
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
make sure the thread has not come off the thread take up lever
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Sep 01, 2012 | Janome Sewing Machines
My machine is not picking up the stitches. I have rethreaded, checked needle and tension.
try these suggestions
Not picking up thread can be several issues
1.bobbin is miss wound
2. bobbin case isn't snapped in properly
3. you're using the wrong type bobbin
4. needle is bent or burred
5. check bobbin area for lint & loose threads
6. little oil--check operation manual for this
7.machine is out of time --done by service tech
8.check automatic thread cutter to see if it’s bent
but most of the time the issue is once again mis-threading or the thread coming off take up lever
sewing machine needles put in incorrectly
Check & make sure needle is in the needle holder correctly.
Check your manual for threading diagram
check bobbin area including case for lint & loose threads
Take the needle plate off & clean under neath it ( if your machine has screws that hold the needle plate on be careful NOT TO DAMAGE THE SCREWS) because a damaged screw that has a burr on it can pull fabric
Each time you start to sew
1.make sure there’s 2 to 3 inches of top thread when you put the needle down for the bobbin thread
2.make sure there is a 2 to 3 inch of bobbin thread so the top thread can pick it up
3.Pull the tail of the top and bobbin thread behind the presser foot
hope these help--please rate this with the thumbs in the upper right hand corner-thank you
Aug 06, 2010 | Sewing Machines
Needle does not pick up thread from bobbin
rethread the bobbin and/or check the bobbin is placed correctly, rethread upper thread
Feb 11, 2010 | Sewing Machines
Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Jun 08, 2009 | Singer 2639
Sewing Machines Logo
970 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
