Question about Bissell Vacuums
I want to replace the power cord for my Bissell Vacuum Cleanere
  • jgioscia Nov 18, 2008
    I need to replace the power cord for my Bissell Revolution Vacuum cleaner Series 3760/4220/6850/6860 (These are the models #'s on the instruction manual, the one with the removable cannister. I received a first response, he told me to take the vacuum apart. How do I take the vacuum apart?
    John Gioscia
  • jgioscia Nov 23, 2008
    I would like instructions on how to take apart my Bissell Revolution in order to replace the power cord
    Brigadier General:
  • 3,614 Answers
The wire connection between the two units is often a source of problems, even in better-quality canister vacuum cleaners. The reason is that there are four sections to the connecting wire: from canister to hose, from one end of the hose to the other, from one end of the power-head tube to the other, and within the power head itself. The end of each section of wire has a connector. If the connection is not made sufficiently, the power head doesn't operate or operates intermittently.
In most cases, servicing the power-head wire connection simply requires that each connector be checked and tightened as needed. If a specific connector frequently makes a poor connection, you can clean the male and female connections with a small piece of emery paper and a can of compressed air.
Broken wires or worn insulators can sometimes be reconnected and wrapped with electrical tape. However, the wire may be located inside the hose, requiring that the hose be replaced as well.
Posted on Nov 23, 2008
  • 19,396 Answers
Check this website:
Vacuum Cleaners, Sweeper Replacement Parts
If you cannot find the power cord on the website, call them at
Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
They will send the replacement at your address.
    Scholar:
  • 181 Answers
The procedure to replace the power cord completely is to open the machine and then disconnect the old faulty power cord and then connect the new as the old was connected.but to open the machine is not a easy procedure as it requires proper tools to do that.as if you have new power cord with you .you can just try to cut the old power cord from very much near to the unit and then calso cut your new power cord and connect the wires of new and old power cord to the same matching wires properly.and check out it should work if the machine is not working properly.but if it is due to any internal short circuit u will have to take it to the proper repair center and get it repaired. NOTE: please do not try to do any service /reparing work when the machine is ON or connected to the electric outlet.it may cause fatal errors. thanks.
Posted on Nov 18, 2008
  • 3,037 Answers
Well, power cords generally aren't sold for replacement, what you can do is go to a local menards or other similar store and buy a cord there and then cut off the other cord, preferably leaving a little to work with and then wire the two cords together. you will need to buy a new plug and also an adapter with the cord and then wire it all together. A menards associate should be able to direct you to the correct parts if you have trouble finding them. You could just take in the old cord and match it up so that it is exact. to actually do this, you will need a phillips screwdriver, a utility knife, and a large wire cutters. Very simple, let me know of any questions that you have while doing this.
  • 1,879 Answers
Amazon : none
eBay : result here
    Top Expert:
  • Bissell Master
  • 81,423 Answers
The cord runs inside the handle, the handle is like a **** shell, a few screws and it comes apart in 2 halves, all you will need is common household hand tools, it will be easy.
  • Marvin
    Marvin Nov 18, 2008
    That is clamm shell
  • 4,806 Answers
You will have to take the vacume appart to get to where the flex is connected to the vacume itself, once inside the job should be straight forward enough to detatch the old flex and attatch the new one, some connections are screws and some have "spade" connectors take note as to which connections they are.
hope this helps and good luck
kind regards
  • Lee Hodgson
    Lee Hodgson Nov 18, 2008
    Here is the Bissell repair manual, i think its the right model of yours
    http://www.bissell.com.au/images/Include...
    hope this helps
    kind regards
Replace power cord on bissell powerforce
Hey Kellie! You should contact one of BISSELL's Authorized Service Centers for assistance with the power cord.
Here's a quick link to locating on in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 05, 2013 | Bissell 6594 PowerForce Bagless Upright...
Need to replace bissell vacuum power cord
Our service centers can replace or repair cords for you. Here's a link to locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Sep 28, 2012 | Bissell 35952 Vacuum
Bissell vacuum shut off and will not turn on again
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest referring to your manual on how to replace the power cord or contact Bissell for troubleshooting steps. 1-800-237-7691.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 15, 2012 | Bissell 37604 Lift-Off Pet Bagless Upright...
My dog ate the e cord ... how do i replace it?
Available replacement parts for your vacuum can be order online from this site:
http://canada.bissell.com/Products/p/pethaireraser/ak/replacementparts/Product.aspx
I don't see the power cord available but would recommend you contact the company through their Customer Support to see if a cord may be made availble; quite possible the cord for another model would be suitable.
Contact information can be found here: http://canada.bissell.com/Customer_Support.aspx
Thank you for using FixYa!
Aug 13, 2011 | Bissell 3920 Bagless Upright Vacuum
The cord is all chewed up. How do you replace the cord?
Vacuum cleaner power cords are just insulated wires. It should be fairly easy and inexpensive to replace. You did not give a brand or model number, but hear is a list of available vacuum cleaner power cords
Jun 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
Dog chewed on the power cord, how do I replace it?
I would try to find a repair shop to replace it as bissell does not currently offer replacement power cords (atleast not on their website) if your power cord is only chewed in one place you could always just splice it back together and use some electrical tape. sorry I couldn't be of more help.
Feb 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need to replace the power cord for my Bissell Vacuum
Should be simple replacement. Once you have the correct replacement cord, just remove the cover, this only involves removing screws, trace the power cord to where is is connected. Once you have found it either write down where each color wire goes or undo one wire at a time and replace with new one. Should be simple fix...just take your time.
Jan 28, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dog chewed cord
http://geeksquad.fixya.com/ThreadView.aspx?prdid=433382&thid=690168
Dog chewed cord
Posted by jnunez918 on Jun 20, 2008
My dog chewed through the power cord (luckily unplugged). Are there replacement parts available and I can't seem to find out to detach the cord from the unit.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are replacement parts available for the replacement of the power cord and to check your owner’s manual to see the schematics of the replacement of the cord. You can check with your local vacuum cleaner dealer in your area or you can call cust serv @ Bissell @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Replace power cord on bissell vacuum model 3596
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=574515
Generic problem for all Vacuums
Replace power cord on Bissell
Posted by bah4995 on May 06, 2008
Replace power cord on Bissell vacuum model 3596
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the Bissell needs a genuine cord because there is a special grommet or cord protector that goes into the bottom of the Bissell of the machine or sometimes you can use a replacement cord and then also use a replacement cord protector as well to replace the cord. If you have a problem then contact your local vacuum cleaner dealer in your area or contact the Bissell factory cust service to get an owner’s manual for the Bissell. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Vacuums Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
