Question about D-Link AirPlus DI-524 Wireless Router
D-524 wont reset and gets no\limited connectivity and...
Cant get to the admin page of the router. I tried all the different reset procedures but all i get is an ip of 169.254.197.224 and a mask of 255.255.0.0. The computer is set to DHCP. I tryed to manual IP using 192.168.0.1 and the copmuter took it without saying there was an IP conflict. This all happend after I tried to reset the Dlink with the computer plugged in. Also I have never done a firmware update. Mine has a HW version B4 with a FW version of 2.03. Any help would be much appreciated ^_^
  • calvin_mille Nov 20, 2008
    RGR, Tried that already. I should have been more specific when I said i have already tried all the different reset procedures. But because that one is the first and most common I thought I didnt need to be specific. But you did remind me of one thing I forgot to mention. The WLAN and STATUS lights continually blink at the same time once every (approx.) 2 sec..
    Genius:
  • 1,124 Answers
Unplug the router from the computer.
Unplug also from the network
Reset the router alone (use the reset hole)
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
Connect the router to the computer only
You have to access to your router typing http://192.168.0.1 user= admin pass= blank (no password) this is a default settings.
Posted on Nov 20, 2008
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
I can't access my routers administration page. It tells me to type in http://192.168.0.1 and all I get is a bunch of search results instead of the administration page
disconnect your modem from router, or turn off your modem from router...
Now try to open...
because the router admin page will be built inside the router itself... so you never require internet connection to be ON for opening the router admin page...
Aug 02, 2010 | Computers & Internet
Hello. I've setup a LAN of 2 computers, a router and a ADSL modem at home, but when I plug both computers to the DLink 524 router, all the lights become less bright and I can't connect to the router, even...
reset set the modem first. then connect the one system to adsl modem. type 192.168.1.1 in browser. enter user name&password.go to interface setup tab-internet--select bridge mode--save and reboot. now remove that take router connect to system type 192.168.1.1 in browser. enter user name&password.go to interface setup or advance setup in that wan tab or internet tab select dynamic ip and lan page give different network address eg-10.0.0.1 for router 10.0.0.2-...254,255.0.0.0,10.0.0.1 save and reboot it will work or just call 08041478653 , 9740575949
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
Dont know username and password to access the modem
First connect your router to computer with ethernet cable.
then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Let me know if you need more assistanse.
Thanks.
Sep 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Ip address
By default the IP address should be 192.168.0.1.
If it will not accept it
>Make sure your computer is wired or connected to your DI-524
XP version
>Try going start>run > type in CMD
>on the black screen type in ipconfig and hit enter.
>Look for the Default Gateway that would be the IP address that your DI-524 is using.
Windows Vista
>Click Start>All Programs > Accessories > click on command prompt
>type in ipconfig
>Look for IPV4 for the Default Gateway and that would be the IP address of your router.
If not allowing to access the login page, try pressing the reset button for 15 seconds at the back of your DI-524 but pressing the reset button will reset the setting of your wireles setting. Once your press the reset button type in 192.168.0.1 on the address bar and you should be having the login page. use Admin/admin for the username and leave the password blank and click ok...
Jan 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant get to the router webpage.
Try admin as the password and username.
That is the default password. Please make sure you reset the password once you get in as to keep your router secure.
Thanks
Dragonrdrz
Please rate me!
Jan 21, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 problem please help
The default username for this router is "admin" without the quotes, and the password is blank (don't type anything.) If that doesn't work, it may have already been changed, in which case you can soft reset the settings to factory defaults by using the reset button on the back of the box.
Sep 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Making a secure connection
Hi Alex26673,
Try a hard reset. You need a straightened paper clip. The Recessed reset button is to the right of the unit's power socket. Press and hold for 10 seconds and then release. Wait 5 minutes for it to finish rebooting and stabilise. Then try you admin login again.
Regards,
Spare head 2.
Jan 04, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
130 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
