Question about Zyxel ES-2024 (91010008002) 24x10/100 Mbps Networking Switch
Hi there I am working on the Zyxel ES 2024 switch. I am getting an error message when trying to connect via HTTP. I can't log in because is says 'user already logged in from another IP'. I have power cycled the switch and it still won't let me on. No other users have loged on to this unit.
    Problem Solver:
  • 10 Answers
How long did you leave it powered off for? It should be powered off for at least 30 seconds for the connection to actual die out.
If not, try click start, run, type in cmd and press enter. Then if your IP is 192.168.0.1 for example type telnet 192.168.0.1 and press enter. Log in through the command line and try enter restart, reload, or reboot. One of these should power cycle through the command line which will kill any "ghost" or active sessions.
Please let me know if this helps.
Thanks,
Adam
Posted on Nov 28, 2008
Zyxel prestige 600
Try the default factory username and pw. User Name: admin Password: 1234
If this doesn't work, review the information from the linked users guide for resetting the device to factory defaults.
http://www.zyxel.com/support/Zyxel-password-changing-procedure-20161213-v2.pdf
Nov 29, 2017 | Computers & Internet
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
I have the Zyxel ES-105A connected in the following way: LAN cable from modum connected to port 1, LAN cable from port 2 connected to my laptop which I use to log in to my modum and LAN cable from port 3...
If your modem is not also a router you can only connect one device to it. You should have a router instead of a switch. Otherwise check the settings on your modem to be sure the ports are open that are needed for the Sling Catcher.
Apr 04, 2011 | Zyxel ES-105A (ES105A)
Is NATing possible on ZyXel ES-2024 ?
The ES-2024 is strictly a switch so it doesn't have any NAT functions. It is just a Layer 2 switch so you will get basic MAC filtering functions and VLAN options.
Jan 25, 2011 | Zyxel ES-2024 (91010008002) 24x10/100 Mbps...
When logging on it says it has encountered a connection problem with the error number 81003004
Try selecting the 'Messenger' dropdown at the top of the window and selecting 'Connfection Preferences' and then select 'Connect via a Proxy Server'. Choose 'HTTP proxy' and then click ok. Try to log in again.
May 12, 2009 | Yahoo Messenger
I have a zyxel p66ohw router connected to my pc via an ethernet card, everything is fine untill my son logs on with his playstation 3, or my wife logs on with her laptop then i cant connect everytime i try...
Make sure that your TCP/IP properties are set to "Obtain an IP address automatically". If you still cannot connect after you change that, and after waiting for a couple of minutes, then open a command prompt and type "IPCONFIG". Make a note of the address at "Default Gateway . . . . . . . . . :" That's the address you need to go to to access the modem's settings..You'll need an ID and password. These would be in the modem's manual.
---to find tcp/ip properties---
It depends from PC to PC, but, try this:
Start (Bottom left of your screen)
Settings
Network Connections
Local Area Connection
Properties
Internet Protocol TCP/IP
Properties
That's how it is on my PC.
Oct 10, 2008 | Computers & Internet
Problems on GS2024-3.80
I just got this switch with 3.8 on it - I'm seeing the fan alert and normal back and forth constantly, like you posted. The hardware error light also flashes as it does this. The fan does not drop below the limit threshold.
I haven't even tried the network yet, so I can't report on that. This kinda stinks with a brand new switch. I got here via google about 10 minutes after plugging it in and noticing the problem.
Nov 27, 2007 | Zyxel GS-2024 (91010056002) 24x1000 Mbps...
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Connection to Access point periodically lost
I have recently gone through the process of setting up a wireless network in my home and I found that a lot of routers and access points 9especially in the wireless N and MIMO categories) have that same problem. Are you trying to go with wireless N? If so then you must be careful what you buy because cross brand connections are not always compatible and also most N routers on the market today do things like drop the connection for no reason. I would recommend the apple airport if you are looking for a good router in the N category. I know they are expensive, but after trying out 5 different routers including all the top brands, I came across the airport and haven't had a problem since. This issue you are having is likely a problem with the router itself.
Aug 08, 2007 | Zyxel G-5100 (ZYAIRG5100) 802.11b/g...
Zyxel ES-2024 (91010008002) 24x10/100 Mbps Networking Switch Logo
296 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
