Question about Whirlpool GU2400XTP Built-in Dishwasher
Can't find power cord to plug in the dishwasher to the wall
I have hoses attached but cant find where the female plug to plug into the wall?
  • 41 Answers
Dishwashers are set up to be hard wired in. however, you can install a regular plug to the wiring for the dishwasher and plug it into an outlet that way. the wiring box is in the front of the dishwasher behind the kick panel. Joe
Posted on Nov 18, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
Bernina artista 165 has always worked perfectly. Ran last night. I turned it off. When I tryed to turn it on today there was no power - checked all cords and outlets. After looking it over for 30 min. I...
Congrats on your upcoming marriage
If the attachment to the machine is 2 prongs (male) and the cord has two small holes for the prongs (female) you can try gently squeezing the plug with the female end to make the contacts a bit tighter. It sounds like the connection is not making contact properly
May 18, 2017 | Sewing Machines
Power up to the control panel \ Dishwasher dead
First, power usually comes in from plug, under the kitchen sink, and shares a socket with the disposal(which is controled with the wall switch) make sure you are plugged into the right recepticle. try a lamp or something in the plug make sure it's got power. then check where the cord attaches to the dishwasher..usually behind the kickplate bottom, right front. Dissconnect power then remove the cover at that point you might find the wire nuts or connection is loose..if that is good ...then there could be a broken wire in the that feeds the timer/controller..those are hard to find...a wire that looks good but within the insulation of the wire, it's broken, usually where the wire bends at the bottom of the door.
Oct 24, 2009 | Maytag Dishwashers
Won't Boot, power cord bad or perhaps female jack that accepts the cord. mine is a HP laptop dv7000
It is most likely the female jack your adapter plugs into. Many laptops can have this port break if the laptop is put into a bag, etc with the power chord attached. Since it is attached to the main board itself, this is very hard to fix. Some vendors however will cover it under the manufacturer's warranty.
Sep 29, 2009 | HP Pavilion dv9000z Notebook
Grounding a figidaire dishwasher correctly. The model number is MD8122RFSO.
Hello ashlyn010507,
What exactly do you need to know about how your dishwasher is to be grounded? The national electrical code treats has dishwashers wired like any other appliance in that a receptacle ( like on your wall) is placed in the general area of the dishwasher and a power cord is attached to teh dishwasher at junction box internal to that dishwasher.. the cord is typically plugged into a 3-prong outlet which has a ground terminal. Otherwise... that is all that is required... If you are hard-wiring it ( as was done years ago) then a power feed is brought into a junction box internal to teh dishwasher and you would wire the hot , neutral and ground there).. Please restate your question if this information didn't answer you correctly..
Regards,
Rick
Nov 28, 2008 | Dishwashers
Dont know how to turn on
The monitor has and adapter type power cord that plugs into the computer end of the VGA cable. Look for a small round hole at the PC end of the cable.
Jun 08, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Power cords
Yes,
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
Apr 17, 2008 | Televison & Video
Replace a dishwasher
Hopefully there's enough slack in your water supply hose for you to just pull out the machine and unscrew the hose.  Be sure to turn off the water before you unscrew it.  You might be able to unscrew the bottom plates to access the supply connection from the front.  Your new machine will probably have a 3/8" female connection.  I'd suggest having a 3/8" street elbow and an adapter for 3/8" male to whatever your plastic pipe.  The other thing to watch for is whether your machine is hardwired for electricity or has a cord and plug.  You can use your old cord and plug on the new machine, if the new one doesn't have one.
prem
Oct 20, 2007 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
294 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
