Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
Electronic panel on dishwasher won't reset after unplugging.
My KitchenAid dishwasher model number KUDS01IJWH0 electronic panel shows flashing lights over "Quick clean up" and Rinse only mode. If I unplug the machine to try and reset, when I plug it back in again the "Control lock" light is on. It wont clear, start or even if I try to follow instruction in the manual by pressing "energy saver dry" mode for four seconds, I cannot get the control lock light to cancel. This has happened a couple of times before and it's always reset by unplugging for a few minutes, then plugging back in. Any tips appreciated.
Thank you. Jan Tidy
5 Suggested Answers
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Posted on Mar 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
Press and HOLD the HEATED DRY button for 5 seconds.
Posted on Jul 07, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
SOURCE: Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Posted on Feb 20, 2010
I have a kitchenaid superba s by s. About every 3 days the freezer quits running and then after about 4 hours the freezer starts working again. What may be the problem?
Are you sure your model number is KSRD22FKST ? Sounds like the defrost timer is defective yet the model number you have above your post shows a W10351625 Defrost Control Board
In the fresh food section above the top shelf the control panel has either a defrost timer or an electronic defrost control. Unplug refrigerator and remove the face of the control panel so you can examine the timer or electronic defrost control for burn marks or signs of heat. The timer or defrost control is most likely what is causing the problems you describedand changing will more than likely solve this problem, Let me know what you find, Thanks Sea Breeze
Post the correct model number if possible, Thanks John Tripp
Sep 25, 2012 | KitchenAid (KSRD22FKST) Side by Side...
Clean light continously flashing won't start
Hello
check the filter in side the machine.
thanks
Jun 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My kitchen aid dishwasher will not start I replaced the interface control board thinking that was the obvious problem. When you go to set the dishwasher to start some of the settings don't always light up...
check all cables especially the ribbon cables from the user interface to the electronic control assembly as steam from dishwashings will create small amounts of corrosion and inhibit signals to and from these 2 components,unplug each,inspect,and reconnect,if this fails,then replace the electronic control assembly located behind the user interface you previously replaced
Mar 23, 2011 | KitchenAid Dishwashers
Green light on control panel constenly blinks
This condition can also apply to a dishwasher that has had the electronic control replaced.
A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle.
Sep 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool dishwasher gu1500xtls2
HI, this is a control fault and you can confirm failure by shutting off the breaker switch or unplugging for 5 minutes. if the unit continues to malfunction after the 5 minute reset, you will need to replace the electronic control board.
Electronic Control board part number----8534866
May 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Mar 31, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
"3 second" light flashing
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
169 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
