D1 code on a Optimax HE 31 C combinaton boiler
d1 code apears when you flush the toilete, after a short time it resets itself
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Posted on Jan 17, 2009
SOURCE: ferroli optimax HE 31C boiler
Setting time is not in manual that we received, however, we did get a separate sheet: Buttons top left-right are A - Clock adjustment B - Operating Mode selecting C - Override Buttons bottom left-right are: D - - E - Programmes F - +
To set clock: 1 - Push A 2 - When the DAY and the CLOCK icons on the LCD are flashing use + and - (D and F). You should set the day of the week (1 = Monday, 7 = Sunday). To confirm the day press A. 3 - The HOUR and CLOCK are flashing use + and -. Confirm with A. 4 - MINUTES and CLOCK are flashing use + and -. Confirm with A.
My LCD is not working correctly, so I have to press the screen gently to see what icons are displaying. Annoying.
Posted on Nov 08, 2009
  • 9 Answers
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
Sep 26, 2010 | Quasar HQ2051TH Air Conditioner
Toilet flushes 3 times when it is flushed.
take off top cover, and check flapper valve for proper seating when flushing.. could be that it is dirty (where it makes contact with tube of tank), and/or the chain length is too short (one link or two)
May 25, 2010 | American Standard 2002.014 - Champion4...
Fault code ( nocn ) on a ferroli boiler
Apr 25, 2010 | Heating & Cooling
Optimax he 31 c whirs loudly but makes no heat
After calling an engineer it turns out it was a faulty fan (The loud whirring should have given this away...) Apparently this is a relatively common fault with this type of boiler. Only solution is to replace the fan which, as of 2010 is still under warranty and can't be bought separately, so you'll need to call Ferrolli.
Jan 08, 2010 | Heating & Cooling
Toilet flushing fills up to level but emptying on its own but water level still at correct level . its a barcelona suite from b and q
If the water level is below the overflow pipe, you need to replace the rubber flapper. This is the part that lifts up when the toilet is flushed and then falls back to the original position after the tank empties.
Dec 27, 2009 | Ginger 31-910-SC15 Satin Nickel Barcelona...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Ferroli optimax 31c
Jan 16, 2009 | Heating & Cooling
Starviewbox code
Nov 28 .
N3l.
00= 31 6F CB 3F 2E 45 5A 04
01= 80 AD D1 D3 80 90 FF 2B
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
