Can't set up my new Nikkai 5.8GHz video sender.
I have purchased a Nikkai A00HR 5.8GHz Video Sender.I tried to transmit from one room to another without success. I then took the entire set to a portable TV upstairs which runs off a freeview box.I have disconnected the scart cable from my freeview box and from my television and plugged the transmitter into the freeview box and the receiver into my TV. I am unable to get any picture or sound on my TV. I have tried a set-up for a plug and play unit but still cannot get a connection. Both transmitter and receiver are set to the same channel. I have tried it on all 7 channels to no avail.Can you suggest what I am doing wrong?
  • 2 more comments
  • drew0011296 Dec 02, 2008
    i have exactly the same problem, help!!
  • Big_Fella_67 Dec 07, 2008
    I have the smaller of the two boxes on offer. I want to leave my Sky box in 1 room and watch the tv in another, without having to extend my Sky cable by loads of metres.
    Having pulled out all the dvd, video etc out of the TV, I still can not receive Sky on the TV.
    Any thoughts please.
  • Anonymous Feb 28, 2009
    we cant get remote control to work to follow set up instructions on tv thought new batteries changed it but still does not work have you any idea whats wrong
  • ben taylor
    ben taylor Mar 02, 2014
    have you tried switch the recever around as the are diffrent ,worked with me
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Posted on Feb 03, 2009
How can i setup my video sender
Posted on Dec 02, 2009
I have a panasonic 3d blu ray player with internet built in. I have my system wired to a hdmi switch and then onto wireless nikkai video sender to my projector this gives me a 100 hd inch screen with...
Try connecting the Bluray player directly to your projector and verify if you have the same issue. If you do not have an issue, your switch is causing the picture to freeze.
Aug 24, 2013 | Audio Players & Recorders
I have just brought a nikkai 5.8 ghz audio/video sender so i can watch my sky in my bedroom but i am having real promblems with it i am getting no picture
I assume you have a 5.8Ghz receiver in your bedroom ? Your TV will not receive 5.8Ghz so you need a 5.8Ghz receiver in the bedroom that will give you an audio out and video out, which you connect into your TV audio in and video in .Put the TV on AV in and voila.
Apr 08, 2010 | Audio Players & Recorders
Can I hook up my tv wirelessly to my home network?
Well I have, using those 2.4GHz AV Video/Audio Senders/Receivers, and as long as the PC you wish to watch has Composite Video OUT, then you can connect the "Sender" to the Video & Audio OUT, this in turn is "Transmitted" to the Receiver, that OUTPUTS again composite Video & Audio to the TV's Composite Video IN and AV IN. Yellow Video & Red & White are Audio IN. Works a treat.
Feb 15, 2010 | Toshiba 32A33 32" TV
My HO800 sentry headphones are brand new....work fine UNTIL static comes and I have no way to clear it, no matter where I relocate in the room. What to do?
1) Try to relocate sender, it might be receiving interference from nearby electronics. 2) Batteries might be low on the headphones, and is unable to receive signal from sender. Look at the manual, to see if there is a way to change the transmit channel on sender, and the headphones as well.
Feb 05, 2010 | Audio Players & Recorders
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
How do i extend mycabletv to another room
You can either use a aerial splitter & run another cable through to the other room, but nowadays the best way is to purchase a video sender, which are two devices that send the signal from the room with the cable box onto the second box which is linked to the second TV in the other room, this means no extra cable is required. Do note under certain conditions it is NOT also possible to watch two different cable channels at the same time.
Sep 14, 2009 | Samsung Televison & Video
CAN'T FIND A PLUG IN FOR A WIRELESS HEADSET ON MY HITACHI 50V720 TV. HARD OF HEARING & HAVE TO TURN VOLUME UP TOO LOUD FOR WIFE.
rather than a wireless headset you might be better off with a video sender unit from what i know the head sets plug into the headphone socket which would mean the wife wouldn't hear anything where as the sender units have a different set up the can also send to another room hope this helps regards Jim
Apr 17, 2009 | Televison & Video
Philips VL1200 Video Sender IR Blaster broken
I managed to get it soldered. Thanks anyway.
Oct 10, 2008 | Televison & Video
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Televison & Video Logo
3,469 people viewed this question
Top Televison & Video Experts
