Question about Acer Computers & Internet
On boot with battery or on power same result. The computer boots to window sign on screen but mouse and keyboard do not work. On reboot tried F2 for setup screen which does work but then once at setup screen the arrow keys do not work to get to a safe boot or any other option. Any ideas???
  • spikew Nov 18, 2008
    The F2 does get to the setup screen then no other keys ( arrow keys work ) to change boot options. I have tried USB external mouse but that didn't work and now I will find and try a USB keyboard next. Thanks.
  • Acer Master
  • 4,806 Answers
I would have told you to go into the bios but seen as you say that F2 key does not work on boot indicates that the keyboard has failed, to check this try another keyboard and see if you get the same result, or if the keyboard is USB try it in a different USB port
hope this helps
kind regards
Posted on Nov 18, 2008
LG Keybo2 Will not stay turned off, have removed battery to try and reset but when I put battery in, just reboots, hold down the OFF button, turns off but then immediatly reboots and turns back on
F keys don't work on reboot. Work on Power on boot.
When powering on the F2 key will get me to Bios Setup, F8 key will get me to Safe Mode, and F12 key will let me change Boot Device. Everything is normal when up on XP operating system. If I reboot, None of the mentioned function keys work. Instead I get a message of a "Keyboard Failure", but system will come up OK. But, on the reboot, I want to use one of those function keys.
I have a DELL 2400 Dimension running Windows Home XP. I am using a Logitech EX-110 (Combo keyboard & mouse)
This seems very similar to another write up on this site.
Any ideas? Don't tell me to toggle the keyboard. I tried it with no positive results
Dec 02, 2012 | LG 10X DVD IDE 452000078
Dimension 8300 boots up to a black screen that says "Alert! Storage battery voltage low" Press f1 to continue, f2 to enter set up etc If I press f2 I can use the keyboard to scroll through...
i think storage battery low indicates that the cmos battery is losing its ability to reatin a charge. try replacing it. if that doesn't solve your problem, you have deeper issues. consult a professional if this is the case.
Jan 31, 2011 | Dell Dimension 8300 PC Desktop
I Have an old HP pavillion model N3410. I am trying to access BIOS or change boot order but it won't let me. I've tried pressing f2 during reboot but it goes straight to normal windows me startup.Also...
Turn the computer off.
Hold down any key on the keyboard, and turn the computer on.
You might get a "keyboard error, press <something> to enter BIOS SETUP".
Also, instead of F2, try F1 or F10 or F11 or F12 or DEL.
Aug 20, 2010 | HP Pavilion N3410 Notebook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
Turn your computer off.
Temporarily replace your keyboard/mouse with "generic" units.
Turn your computer on.
Check that the F-keys work.
Now, do the F-keys work correctly?
Or, do you still get "keyboard failure"?
Jul 22, 2009 | Computers & Internet
Mx 3200 keyboard runs but won't type
windows xp info.
go to start,
control panel,
device manger,
click on x at keyboard see your keyboard there right click delete keyboard shut down and reboot leave keyboard plugged in...and it should find and reload the keyboard.
if this does not fix the problem..shutdown the computer unplug the keyboard and mouse...reboot the computer and let load all the way...I know you can't do nothing about signing in or working on it
but let load all the way after finished loading push button to power it off are unplug it...then replug the keyboard and mouse and boot it back up should fix it...
Apr 05, 2009 | Logitech Cordless Desktop MX3200 Laser...
Computer boots up, but can't use keyboard or anything else
sounds like a problem in windows may have to reinstall the os
Mar 30, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
