Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
ICE MAKER OUTLET FLAP FEEL OFF
KITCHENAID KSCS25INSS02 SIDE/SIDE
NEED TO REMOVE FACE COVER TO REPAIR FLAP, DOES IT JUST PULL OFF? TALKING ABOUT BLACK PLASTIC TRIM AROUND ICE MAKER FRONT ON LEFT DOOR.
aborcass
  • 2651 Answers
SOURCE: Rust
assuming that this is not stainless steel model, for that shouldnt be rusting. but that being said if you look closly at the underside of the facade surrounding hte dispensor youll see 2 little slits approx. an inch in from either side along the bottom, gently pry off with a screwdriver from theses points,( should twist off and lift up, to reinstall simply "hang " on top clips and snap back down into positon.
Posted on Jul 09, 2008
  • 958 Answers
SOURCE: how to remove housing cover in front of ice maker
hi,
here is a picture of your dispenser, i hope it would help you solve your problem.
http://www.partadvantage.com/catalogimage.php/IWZM5EII.gif?geometry(1000x1000)
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
MY REPAIRMAN
  • 61 Answers
SOURCE: need to remove front black plate cover on my kitchenaid
MOST OF THEM YOU PRIME A FLAT SCRUE DRIVER ON THE FRON LOWER PANE THE Y HAVE TWO SMAL SLOTH AND TWIT THE DRIVE AND THEY WILL COME OF AND DO BOUTH SIDESRT AND LF.
Posted on Jan 25, 2009
tborn6
  • 700 Answers
SOURCE: Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Posted on Apr 04, 2009
ynogami21
  • 670 Answers
SOURCE: replace or repair ice maker
There are actually some things that needs to be considered.
How long have you been using the unit? Is it still efficient? How much will it cost you to replace or repair it?
Once you've answered all those questions then it would be easier to decide weather you want to replace or repair it.
For repairs:
you can try calling these guys:
Phone number: (877) 247 0880
Website: http://www.247usaappliance.com
Hope this helps!
Posted on Jun 10, 2011
My ice make has stop working
this unit has a wild ice maker on this unit, they used a standard ice maker but it also has an optic eye going across that control also. first you want to make sure your getting water to unit ..there is a flap on the left side of the freezer make sure that it is connected properly and not obstructing the beam that goes across to the right side ...you wont be able to see the beam but should be able to make sure the door flap is not getting in the way...you can actually remove ice maker and pull front cover off hold the left side flap down and jumpo out the ice maker on the "t" and "H" termiankl and advance the unit through the cycles... the most common problems wih this unit was either the gear on the ice maker broke or the optics went out on the unit... hope this helps repost with anymore questions
Jan 06, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ice maker keeps freezing up and then it won't make ice cubes, water comes out, but no ice. We have taken a hair dryer and melted the ice but it came back. Why does it keep freezing up? It is a side by...
If your talking about the ice dispenser freezing up, check that the doop flap is closing properly. Sometimes a plastic eyelet will break and the flap will sit ackward. They make a kit to fix that even though they say you have to buy the whole door.
Oct 28, 2010 | KitchenAid Refrigerators
I have a KitchenAid side by side and my icemaker is not working
Check the black 2" fill hose going from the top of the freezer to the ice maker fill cup , to see if it's frozen up . Also check the optics system for proper operation . Open the freezer door and the laser should flash 2 times , pause , flash2 times , pause etc. Close the flap on the left side and the laser should go off . If the laser does not come on when the door is opened , then the ice maker is in the harvest ( dump ) mode . If it stays this way , then ice maker is bad .
Sep 12, 2009 | KitchenAid KSRG25FK Side by Side...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a KitchenAid [KSRG25FKSS03]. We turned the ice maker off for a period of time and recently turned the switch back to the on position, but now no water is flowing from the black rubber outlet into...
sounds to me that the water inlet line is frozen. If you feel of the black rubber outlet, it will probably have ice in it causing it not to pour water in thus no ice production, Remove your door that is in front of the ice maker and use a blow dryer and thaw the line. Hot water can be squirted up in the line to thaw it quicker and do a more efficient job. Once you clear the line then your no ice days should be over. It may do it again and if it does then you will need to do the same thing again adding replacement of the water inlet valve.
Jan 06, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Ice maker not working
then you either after doing this have a water to the ice maker problem, or an ice maker issue
go to the water valve and disconnect the small plastic line at the water valve and with a cheater cord connect it to the water valve, naturaly remove the factory connector at the water valve first and plug your cheater cord into the ac if you get water out of the valve the valve is good if you do not the valve is bad
if you get water out of the valve then you have a problem in the ice maker IF the line to the ice maker is clear and no obstructions
Apr 12, 2008 | KitchenAid KSBP25FKSS Side by Side...
Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Thanks but, I knew this part was working
Iceman, here's a little deal I wrote, check it out, Catriver
Diagnosing Whirlpool and Kenmore s/s with ice bucket in door.
Upon opening of the door the emitter light should flash 2 times with a pause repeatedly. Then when holding the left side emitter flap down the light should stay on steady. If you have this scenerio, your emitter boards are working properly. If you do not, check the following:
First thing to check is the position of the ejector blades on the ice maker. They should be at rest in the 2:00 postion. If you find them in any other position than that, it’s more than likely a module failure. The module is located on the front of the ice maker. To remove the ice maker from it’s mount, remove the quarter inch screw holding the harness cover on the lower right side. Remove the harness cover. Now the ice maker will pull straight out. Unplug the harness. The module is held in by 3 screws in the corners and will pull off.
Often, the black fill tube located on the ceiling will freeze causing a no water fill. This can be fixed by thawing with a hair dryer or some sort of baster using hot water.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
