Question about Nakamichi SoundSpace 5 Shelf System
Thanks I tried this and it didn't work. Yes, there was a guest at the house who punched alot of buttons trying to figure this out
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the "Ask Me".
To your Nakamichi Soundspace concern, a few more ideas to explore/try:
  • is it possible to completely forego parental control? disable it in all levels.
Additionally, this line of thinking was already forwarded by another expert, teknowolf.
Good luck and Thank you again for using FixYa.
Posted on Nov 18, 2008
So i was walking outside and then it suddenly started raining and i tried to cover my nokia n97 but it got a bit of rain on it. I ran back to my house with my phone in my hand. It worked until the battery...
hi have you tried other battery? if not, kindly replaced it. if yes, pls bring it to service technician to open it i guest inside board is wet due to rain, they will used hot air blower to dry it. thanks
May 09, 2011 | Nokia N97 Cell Phone
Im trying to change the unit of measure i go into "design" but "unit of measure isnt highlighted as a usable option unless im in the home screen where it tells me i can not use this option...
Using Quick start is like a napkin sketch or a fast layout. After you click Continue, you go to the project stage. Therefore, after you press the "Continue" button you will be able to Save, Import, Print, Move, enter inside the house or set the precision and units, as well as use all the Punch features
These are the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Facebook
Apr 21, 2011 | Punch Home and Landscape Design Suite for...
HI,my freezer runs fine,but I noticed where the motor side is,should there be a fan??,I feel no air moving.didn`t try to take off cover an look.an the freezer gets alot of ice at the top sides.thanks
Good day,
Unlike most refrigerators and upright freezers, they don't use a fan motor. The condenser coils are imbedded in the walls of the machine, and need no supplemental cooling.
As to the ice buildup, sounds as if the gasket isn't sealing well enough. You could try cleaning the gasket thoroughly, and check the alignment of the lid to the body.
Appliance parts houses carry a food compatible spray, which may help make the vinyl more pliable.
If that doesn't work well enough, then the only option is replacing the whole gasket.
With the model number, check with the supply house to see if the gasket is a replaceable style.
Nov 03, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Blinking red light,
It seams alot of people have this same problem All must get ahold of manufacturer and report this it must be there pump's thank you for useing fixya
Jan 14, 2009 | Noritz 6.3 Gallon Residential Tankless...
Subtitles
if you have cable or sat you need to make sure it is turned off there to.
Jul 27, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
My iphone won"t turn on
you should be able to reset it by keeping pressed the top button and the home button for more than 10 seconds when it si connected to you computer. let me know if it works!
Apr 08, 2008 | Apple iPhone Smartphone
Xbox live
Make sure that you have an Xbox Live Gold subscription first,
Second You won't both be able to play at the same time enless it is a game that provides guest support(and in some games WITH) guest support you cannot play anything ranked online. To sign in a game with Guest support hit the guide button on the second controller select choose profile and scroll down, if u see "Guest" as a profile and you did not create it, then that game has guest support, and you can both play.
______________________________________________________
If u are just trying to let him play alone then you have to sign him in how you would normally
Jan 15, 2008 | Microsoft Xbox 360 Console
DVD Player set to display settings unusable on available TV ( resulting in blank picture)
Ok folks, I've found it......turn the unit off.....press and hold the << button on the unit....should be the button closest to the power button....then power the unit on....that's all there is to it....as it turns out, before you set the unit to "progressive scan" it warns you about that and tells you how to reset it...
Mar 24, 2007 | Pioneer DV-260 DVD Player
Nakamichi SoundSpace 5 Shelf System Logo
89 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
