Question about Euro-Pro Dressmaker 998B
Cant get the bobbin out
I bought the little dressmaker2 from hobbylobby. the box got thrown away,and I have no directions. I cant get the bobbin out to change bobbins. I need help to use the machine. thanks, Victoria
    President:
  • 2,692 Answers
Here is the website for you model to download a manual from written in adoby format. If you don;t have adoby reader software, download it  from the ADOBY website, also for free .
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=998B
Posted on Dec 26, 2008
After refilling bobbin and changing thread the machine began bunching up on bottom of fabric. What did I do wrong?
Hi JoAnn. Check the take up lever. It sounds like when you rethreaded your machine you missed the take up. It is the arm that goes up and down toward the left end of the machine. Thanks
Jan 21, 2016 | Sewing Machines
The bobbin thread on my Juki DDL-8700 is loose and bunching up. I have messed with the tension on both top and bobbin and I cant get it tightened up. Please help!
Hello Lacinda have a good day to you concern loose or missed stitches please check next: 1-try to change bobbin case with new one. 2-check timing between needle and hook by -make needle bar at lowest position and you can see two mark line at needle bar. -bring the needle bar at second line from down side then check the flat part from needle comes with tip of hook ( if yes means timing is OK , if not means you need to adjust the hook timing . 3-check the ginger guide for hook try to move it foreword or backward to pass thread smoothly. if this is helpful OK if not please send email, i try to do the best to help. best regards ASHRAF ABOZID CAIRO - EGYPT aabozid@hotmail.com
Feb 24, 2015 | Juki DDL-8700
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
MY MACHINE IS GATHERING UNDERNEATH AND
the teeth of your sewing machine was lowerd thats why if you stich did'nt go forward, adjust it afward, to adjust open the plate and thight the small bolt.
Mar 31, 2010 | Husqvarna Huskylock Computerized 905
Bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore cant thread bobbin
Sounds like you haven't engaged the bobbin into the wheel that runs the threader...
I had to pull the thread thru one of the little holes of
the bobbin and run the machine carefully to get it to
start threading.
Hope this helps.
Apr 26, 2009 | Sewing Machines
Brother computerized c s6000i will not pic up bobbin thread
Have you got the bobbin in the correct way around, also have you put the needle in correct with the groove in the front of you.Are you using the correct bobbins,if yes to all these your machine has thrown it timing out in the bobbin.and needs to be looked at.
Jan 16, 2009 | Brother CS6000i Computerized Sewing...
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Bobbin
have good eye hand cordination and lick the end of a perfectly cut thread up to the bob make sure not too have any loose thread on the end or will not go threw
my mother when i was little taught me to sow on and old 32 singer up her new 65 singer when she bought it used i never could use the stick to sow
or you can cut a piece of fishing line little fast acting glue to the ends together or grease thick sowing grease this will keep fish line and thread together as your putting in bobbin
fishing line about 1/2 foot piece
May 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Euro-Pro Dressmaker 998B Logo
113 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
