Question about Acer Aspire 3000 Notebook
I have a Acer Aspire 3000 notebook computer that I want to hook up to a 19" external monitor (Septre LCD Model DCL9C) I thoughout that after plugging it in to the rear monitor port adn power source that I only needed to press Fn F6. But nothing happens. Any Idea What am I doing wrong? are there drivers I have to load?
  • 100 Answers
According to the Aspire 3000 User Guide, you should be able to use Fn and F5 (not F6) to toggle the display selection. Try that first. If that doesn't resolve the problem...
Your laptop probably has the SiS Mirage 2 graphics processor. It's max resolution is 1024 x 768. The Sceptre DCL9C will likely default at 1280 x 1240. Try backing the resolution (in Control Panel) down to 1024 x 768 - for the external monitor. Also, hit the AUTO button on the monitor. It might reset itself to be compatible with the SiS video. Lastly, download the latest drivers for your OS and the SiS Mirage 2 video adapter.
I hope this helps! Please post rating, if it does.
Posted on Nov 18, 2008
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled TV/HDMI/VGA are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
My Netbook Acer Aspire One will not hook up to the LCD projector.
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
How to connect external monitor to aspire 3000
plug in the new monitor to the notebook, then right click background and then click properties. Then go to the settings tab, at the bottom of that click advanced. Next Click monitor. There you should see the external monitor for you can set the display to this one.
Oct 25, 2011 | Acer Aspire 3000 Notebook
When conneting Acer Aspire 5810TG to a Samsung LCD LE32M6. The Samsung LCD shows 'no signal'.
On most laptops, you need to turn on the external monitor connector from a function key on the keyboard. It doesn't automatically sense you've hooked up the other monitor. On your model, hold down the Fn key and press F5 to switch the external connector on. Here's the page from the user guide with the key combinations you might find helpful:
Dec 17, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
Have acer aspire netbook. what cable do I need to hook up to LCD?
Do you want to connect an external LCD screen to your Acer laptop?
The Acer will have a blue 15pin Dsub female video connector. The standard 15pin monitor video cable will connect to the Acer's video port.
Sep 27, 2009 | Acer Aspire One PC Notebook
I have an acer aspire 3000 and there is a white single line going across the LCD, I put an external monitor on it and there was no line on the external one. Any help on this?
UR LCD IS DAMAGED first try to change the inverter cable inside the lcd if it helps then replace lcd if doesnt solve ur problem
pls rate me fixya if i solved ur problem
Mar 04, 2009 | Acer Aspire 3003WLCi Notebook
Connect a monitor to connector 2 or 3
Hold down the Fn key and press F5. This toggles between laptop screen and the external monitor.
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 3000
Have you tried to disconnect the external monitor and just booting to the laptop? If this works, then use the "e" key next to the power button to add the second monitor.
Jun 20, 2008 | Acer Aspire 3000 Notebook
Most latop are on board video rather than a seperate card.
If the external adapter is working with an lcd screen then it must the laptop screen that is faulty and not the video card/ on board gpu.
Jan 08, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
283 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
