Question about Apple Power Mac G5 Desktop
I Cannot Reset a New Password
Someone has broken into my G5 and now my system has stopped responding to my original password.
I have tried the gray disk 1 and the reset feature, but that did not work. I got a message that stated that the, SYSTEM ADMINISTRATOR (ROOT) did not save the new password.
Please let me know how I can correct this.
Thank you.
  • 2 more comments
  • EVERETTE NICOLLS Nov 19, 2008
    I followed your instructions and here is what happened.
    I am using the G5 with Leopard.
    After booting from the disk, I went to Utilities and Reset password.
    The Reset Password box came up with the image of a dvd disk: Mac OSX. . . 1 Disc 1.
    Everything else in the box was in light gray. I clicked on the disk and up popped:
    System Administrator (root). I clicked on the up and the down arrow but I did not
    get another feature. Thus, I could not reset my password as instructed by you.
    This Mac is OSX 10.5.5 and the start up disk is 10.4.
    After using the Reset password feature, I also looked at the Start up Disk feature.
    There I was given the choice of using my install disc, the Mac HD 10.5.5 or the
    network startup. Neither of those worked.
    Only System Administrator (root) pops up when I used the reset password feature.
    Are there any other solutions, please?
    I appreciate you assistance.
    Sorry, I forgot to add that I do not know how to get to FIRMWARE. My Desk Top is not coming up when I turn on my computer. The only window that opens is the password window. I suspect that I might be having problems with the FIRMWARE.
    How do I get to that and disable it?
    Thank you for your help.
    Thank you for your patients with me. It is just that nothing is working here. I follow the procedures and I
    continue to receive the same results. I think that I must have a way to enter FIRMWARE.
    The only feature on my Desk top that is coming up besides the password log in box is the purple Leopard screen. So, I cannot enter my system preferences. How do I get to FIRMWARE?
    Do you think some kind of Spyware was placed on my computer? My girl friend broke into it
    to read my e-mails and it has not worked since.
    I have been to the Apple site to read up on FIRMWARE but it does not give instructions on how to enter that feature if the problem is as mine happens to be.
    Please get back to me.
    Thank you.
    Something is wrong here. The image you sent of the Reset Password box with the two hard drives inset
    that does not occur on mine. When that box comes up, only the install disk is shown. When I click on that as I said, I get the SYSTEM ADMINISTRATION (root).
    The only time that I see both drives is if I go to the first feature under Utlilities: STARTUP DISK.
    I guess that I have come to the end of the road.
    Well, thank you for your time and assistance.
    Warm regards,
No one seems to understand the problem. How do you disable or reset the firmware password? All the basic keystrokes are disabled with firmware password protection enabled. They say the only workaround is something physical, but what is it? Removing the battery and ram does not help.
Any real ideas?
Posted on Oct 24, 2009
  • 38 Answers
Hi there
You'll need your install disk.
  1. Start up from a Mac OS X Install CD (one whose version is closest the the version of Mac OS X installed). You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
  2. Choose Reset Password from the Installer menu (or Utilities menu in Mac OS X 10.4 Tiger). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
  3. Select your Mac OS X hard disk volume.
  4. Set the user name of your original administrator account.
    Important:Do not select "System Administrator (root)". This is actually areference to the root user. Do not confuse it with a normaladministrator account.
  5. Enter a new password.
  6. Click Save.
Posted on Nov 19, 2008
  • 1 more comment
  • Paul Burrows
    Paul Burrows Nov 19, 2008
    Hi Everette
    Yep it is a bit of a pain to do but does work. I've done it on a few machines. You cannot go in as "system admin'
    Rather than me trying to explain it all to you apple have a really good support section. Just click on the link below. If you still have a problem come back to me.
    Good luck
  • Paul Burrows
    Hi Everette
    You should not have a problem with the 10.4 disk.
    You just need to go through the firmware bit of the site.
    Looks a bit complicated hopefully you'll get through it OK.
    Firmware bit.
  • Paul Burrows
    OK Everette
    The machine must be switched off when you put the install disk in. start the mac up holding down the 'c' key. The window you should then get is the language selection to install. Click next.
    Now stop there. From the top of the screen you should see the menu for the install DVD. Click on utitlities. It will drop down to give you a selection.
    Your first try should be reset password (second down) this will open up another window that shows you the drives. One will be the DVD the other your hard drive. click on your hard drive icon.
    Click on the 'select user to change system admin (root) the password boxes should be available to you. Put the new password you set in the hint box (for now). And you should be away.
    Unless you original set a firmware password. It is blank by default. Your problem is not a firmware issue.
    I'm afraid the last resort is to re-install your system. Archive the old one and then you can get all your private stuff off out of the archived users.
    I dout very much that spyware or such is causing any problems.
Can u reset my password
I am not sure what operating system you have. Try going into control mode as the PC is booting up and add an admin level user with a new password. Use that to change your original password. If that doesn't work try to use someone else's PC to get online and download one of the many password recovery programs.
Jun 04, 2014 | Computers & Internet
How to reset administrator password on windows server 2012 raid server? My computer is HP HP ProLiant ML110 G5 with raid 10. I have try to use Chntpw to reset the lost password, but it cannot detect my...
Which operating system ??
The Hewlett Packard ILO (Integrated Lights Out) tool lets a network administrator connect to a remote Windows Server system.
This process enables the administrator to perform troubleshooting and problem fixing as if the server were connected locally.
If the password of the account used for connectivity becomes corrupt, it can be reset from within the Windows interface.
Log on to a Windows computer that has a connection to the HP ILO.
Click the "Start" button. In the "Search" box, type "lusrmgr.msc."
Press "Enter" to open the User Management console.
Double-click "Local Users and Groups."
Click "Users."
Scroll down to the HP ILO user account.
Right-click on it. From the drop-down list, click "Set Password."
Type in a new password.
Click "OK."
Retrieving administrator in xp
Recover the lost administrators password in Windows XP
Slightly more work needed if you lose or forget the Windows XP
administrator password.
1.First reboot Windows XP in safe mode by re starting the computer and
pressing F8 repeated as the computer starts up.
2.Then (in safe mode) click Start and then click Run.
In the open box type "control userpasswords2" without the quotes
I have just used quotes to differentiate what you have to type.
3.You will now have access to all the user accounts, including the
administrators account and will be able to reset the lost password.
4.Just click the administrators user account, and then click Reset
5.You will need to add a new password in the New password and the
Confirm new password boxes, and confirm by clicking OK.
All done, you have recovered the lost administrators password!
Sep 23, 2013 | HP ProLiant ML110 G5 (444809-001) Server
My siemens sx66 cingular has alphanumeric password on, someone tried entering wrong password severally and the phone is not accepting my original password any longer, i tried hard reset and its not...
Hello Sambicho.
The a1b2c3 may be the 'password reset' code after which you must enter YOUR original password, which it hopefully still has stored in it's memory.
Otherwise the 'someone' may have changed the user password.
Hope this is helpful.
FYI: passwords are case-sensitive.
Oct 11, 2017 | Siemens SX66
I have installed a brand new 10.5.6 on my G5 2x2 dual. After i had installed the system i configured the safety so that it would not even be possible to reboot without password from another disk or drive....
Trying booting from the Mac OS X install disc. insert the disc while holding the "option" key on the keybaord select the Mac OS X disc. once it has started select the Utilites from the menu bar from there you will see a "Reset Password.." select the hard drive select the user account enter password reenter the same password give yourself a hint to the password
at the bottom reset the "Home Folder Permissions and ACLs"
click save
reboot the same way, holding the "Option" key select the hard drive enter the password for the account you just made
once you have booted into the system go to: Apple menu (top left) > System Preferences > Startup Disk
make sure that you have your hard drive selected this makes it so after a reboot it will boot from the hard drive and not a disc.
Nov 20, 2010 | Apple Power Mac G5 Desktop
Learn how to change or reset an account password in Mac OS X, including the original administrator account password. You might need to do this, for example, when someone has lost or forgotten his or her account password.
Tip: If you forget your login password and your home folder is protected by FileVault, seeI forgot the password to my encrypted home folder
Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the username whose password you want to change.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Important: Passwords for administrator accounts should not be blank.
Feb 24, 2010 | Microsoft Windows Vista Home Premium with...
Have asus computer. fingerprint access vey variable t times blocked. password - not responding ? forgetten > wrong How do I chnge passowrd if ai cannot get original right?
FInally got back in with fingerprint. Opened new admin account and registered password. Then went to old account and reset password--did not ask me the original. Only problem---when shut down and restarted had to reconnect to internet ( via wizard!!) and have probably lost some files --howevere not important. Will when have time re register fongerprints as scanner ? function.
Oct 23, 2009 | Computers & Internet
Mac powerbook G4, I Cannot Reset a New Password, c with disk or apple + s do not work
Do you know someone with a USB or Firewire external drive box. If you do, take you drive out of your computer, install it into the box. Your friend may be able to copy/move you data/information to CD/DVDs and then format your disk. There is nothing that can survive a format. After your drive is formatted, create a partition on it and copy your data/info to the partition. Your friend should make sure his antivirus/malware is up to date. He wouldn't want to catch what caught you.
May 29, 2009 | Apple Power Mac G5 Desktop
G5 imac.. with leopard can not get past sign in
If you've forgotten your password, you can reset it with the discs that came with your computer:
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
Dec 29, 2008 | Apple Power Mac G5
If you have the install disk, restart the Mac and hold down the C key after you hear the startup chime. This will start from the CD. Under the Installer menu, you will then have the option to reset the password for the admin account, which will enable you to reset any user password.
Instructions from Apple are here:
Nov 19, 2008 | Apple Power Mac G5 Desktop
Apple Power Mac G5 Desktop Logo
410 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
