How do you reset the Siemens RDH10-RF Wireless Digital Room Thermostat and re establish communication?
2 Suggested Answers
ayshansaeed
SOURCE: Need a free T4 RF
I have T4 RF wireless thermostat.When you turn off heating from thermostat,for some reasons after 1 hour boiler kick on and radiator feel hot again.please give me solution.
Posted on Apr 10, 2012
Need a free T4 RF Wireless Room Thermostat British Gas manual
Jul 14, 2011 | Heating & Cooling
Worcester DT 20 RF Room Stat, when batteries were replaced in correct positions the unit still did not show any signs of life
It is recommended that you use all new batteries when replacing them in the Worcester DT 20 RF Room thermostat. Rest the power on the heater with the thermostat near by, this will reestablish wireless communications between the two. You will need to reprogram the heaters timer as well.
Dec 11, 2010 | Bosch Water Heaters
Hi i'm trying to connect my i phone to my wireless network and i have not got the password any idea on how to get it? I've reset the router as described in other soloutions, thanks ivan
Use an Ethernet cable to connect a desktop/laptop computer to the router. Then, using the PC, you can "configure" the "wireless" capability of the router, and you can establish an SSID and a password. Then, configure your iPhone to _use_ that SSID & password to connect.
Mar 07, 2010 | Siemens SpeedStream 2624 Router...
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
I have to turn the modem off and back on every time i get on my computer to get it to connect to my dlink router. how can i solve this
If it is wired through the LAN ethernet connection directly to your computer it is cause by unplugging the ethernet. Routers and modems hate a ethernet cable unplugged and will stop communicating if unplugged. You will have to reset almost every time. When reset the router goes out and looks at what is connected and then handshakes with it. If it is a wireless issue you can reset your wireless setting in your control panel. This shouldnt happen as your wireless network should always be broadcasting. Generally, to connect back to a router you only need to unplug the router to re-establish the connection to the modem. Going all wireless is the only way to fix this
Oct 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Targus RF PAUM005 Mouse Not Working
do you have the CD that came with the hardware???
seems like the PC can't communicate with the hardware. although it see something out there, but it doesn't recognize what it is.
even the machine is says this device is working porperly, you still need to install the driver, and the configuration for the device. that's why the receiver doesn't flash.
try to install the drivers and the configuration application.
Oct 23, 2008 | Targus Wireless Optical Mini Mouse
We are ntrying to hook up a none wireless modem with our old wireless modem
this is ok if you use the hardwire router first from the modem then the wireless. The hard wire modem needs to establish its address first then the wireless. Take care.. Be mucho blessed...Mark
Jun 29, 2008 | Siemens Computers & Internet
PROGRAMMABLE ROOM THERMOSTAT
I found this on a search:
"I have the full set of instructions, contact me at gjb@eggconnect.net
Not a very reliable system, transmitter keeps resetting to 17:25; locks up. Whole system then requires setting up from scratch. Had a replacement transmitter, no change, and same faults.
GJB"
Perhaps this can help.
Mar 15, 2008 | Computers & Internet
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
