Question about Zyxel ZYWALL 35 Firewall
Routing problem Hi, I´m having a problem regarding a Zywall 35 that I am configuring for my company. I have configured the two WANs and also my LAN Also configured the firewall rules to allow everything from LAN to WAN1 and WAN2. Created diferent policy routes to try to route the packets from the LAN to any WAN but it´s not working. I tried creating a policy route that said 0.0.0.0 source to 0.0.0.0 destination from the interface LAN use WAN1 and when I try to ping an external host that is on WAN1 I get, destination unreachable from the zywall. I tried creating a more explicit policy route by using a defined ip range for the destination, but still doesn´t work. Also tried creating a static route, but the same error keeps appearing, even tried to establish an SMTP connection from LAN to WAN1, but didn´t work. Any ideas on what may be wrong, or misconfigured? My LAN is 192.168.1.x, my WAN1 is 172.16.30.x, my WAN2 is 10.1.1.x
  • nageswar Mar 28, 2008
    I configures zywall 35 router with two wan ports and one lan port. My router is working fine but the problem is I want to set a policy route for clients with packet legnth. I need to configure a packet legnth for clients.
    How to configure Packet legnth for clients
    Regards,
    Nageswara rao
    nageswararao@ggitl.com
    Scholar:
  • 27 Answers
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Posted on Jan 29, 2007
I lost the password, and i can not access the zywall 10. How can i reset the zywall to the default configuration?
you need to use the reset button on the back of the device: it is quite small, so you need to use a needle or a small sharp object to press it. You can find it under the label "Reset" on the back of your router.
Hope it helped,
Franz
Mar 01, 2011 | Zyxel ZyWALL 10 Router
How to install my belkin n150 wireless router on my netbook that has no built-in CD-Rom?
HI Gilbert,
Can i have the brand name of the modem , Your Internet service provider name , so that we can configure the router with using the CD.
We have another method to configure the router that is manual configuration method.
Thanks & Regards,
prema
Oct 21, 2010 | Belkin Computers & Internet
I cant get acces to my Modem or Wifi using "192.168.0.1? Help
May be 192.168.0.1 is not the address to configure that router.
Start, Run, CMD to open a command prompt:
Type the following command:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
example results.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adamprince>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Adamprinces
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine III Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-0A-48-08-24-52
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.6
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 202.27.184.3
Lease Obtained. . . . . . . . . . : Tuesday, 24 August 2010 5:35:33 p.m.
Lease Expires . . . . . . . . . . : Wednesday, 25 August 2010 5:35:33 p.m.
____________________________________________________
The address to configure that router is 192.168.1.254
Aug 26, 2010 | Computers & Internet
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
How to configure static route between 2 LANs?
the command what you have given is correct as per your explanation. If you could post the configuration, it will be good to fix the issue.
Jun 10, 2009 | Cisco ASA 5510 Firewall
Eigrp configuration
Hi Friend,
1.Enter into your configuration mode(#)
2.type router eigrp 10(Autonomous system)
3.type the network address
eg., network 192.168.10.0
netwok 192.168.20.0
4.type no auto-summary
These are the Configuration of an Eigrp routing protocol
Regards,
ayyasam
May 21, 2009 | Cisco (1841) Router (cisco1841)
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
Configuration of router
hi ashrafchotoo,
The details of configuring a wireless router depends on the make and model of the router. The overall process is not that dissimilar between the various wireless router solutions.
Here is a link to D-Link's FAQ page on their wireless routers. You can start with their product configuration details and extrapolate it to other wireless routing products: http://support.dlink.com/faq/results.asp?question=General%20Wireless
Thanks for using the FixYa services
Regards
Feb 12, 2008 | Apple AirPort Extreme Router
Full Duplex
By default, I think these come with auto-sensing turned on, but I may be mistaken.. do not have one available, but do have the manual link if you need it:
ftp://ftp.zyxel.com/ZyWALL_35/user_guide/ZyWALL%2035_4.03.pdf
or:
http://tinyurl.com/2k9gth
I reviewed the entire document and did not see a section on configuring duplex, although it may be in the Bandwidth section.. since they do not show all the configs, I am not sure....
Dec 21, 2007 | Computers & Internet
Zyxel ZYWALL 35 Firewall Logo
860 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
