Washer motor tries to start then stops
My daughter call and said washer stopped working . I went the next day turned it on and everything worked at first . I watched the motor turn the drum and cycle back and forth as well as go into a spin cycle . I put a load of clothes in and started the washer . Washer filled with water and started to cycle the drum back and forth . You could see the motor try to start a couple of times and then power off the washer . You could wait a few seconds and push the start button and again the same thing would happen . I then removed the drum belt and started the washer again with the same results . That's where I am at this time . Is it the motor control board or maybe a bad motor ?
MR G
Thank You
    Habit-Forming:
    New Friend:
  • 31 Answers
There are a number of possibilities but the easiest to check is if the brushes are worn down which would need to be physically checked or you could have a loose or broken wire in the motor block then you get on to the possibilities you highlighted which would require an engineer to test them.
Posted on Mar 28, 2017
  • 19 Answers
SOURCE: Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Posted on Aug 16, 2007
SOURCE: Computer board shows UL even when very few clothes are in the washer
try to unplug and plug back after 30 seconds.
Posted on May 09, 2008
SOURCE: Kenmore 80 series washer model #11092587210
My washer won't work after we moved it into a new house, and I found a fuse in the floor beside it but couldnt find anywhere it would go. Is the fuse from the washer?
Posted on Nov 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
oldmanewtoys
  • 414 Answers
SOURCE: GE Spacemaker top load washer U6 error code
level washer and do not overload capacity
Posted on Mar 09, 2010
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Is there a fuse for the washer fluid pump?
Yes; but it usually is tied into other systems, if everything else is working, then more then likely it is the washer motor. Turn on the ign. and have someone hold the washer handle in and tap on the washer bottle (that is if you can get access to it) If the pump starts working keep it running for a little while then start and stop it 4 or 5 times. The problem with washer pump motors is you only use them occasionally and because of that then can seize up. If you get the motor working use it every now and then to keep it loose.
Mar 06, 2013 | 2001 Oldsmobile Intrigue
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Mar 28, 2010 | Garden
Kenmore model 22702-100 washer won't pump water out; has come to a complete stop.
if the washer wont start at all look on the back if all wiring connections are good if so the waterpump motor went out if everything else works,cus thats the only thing that sucks the water out,if the info was a good help to you please leave a comment ,thank you
Sep 01, 2009 | Kenmore 23822 Top Load Washer
My daughter put a big blanket int he washer. it started and then after a few minutes it stopped. I had to untangle the blanket after the motor stop working. now it will not even turn on. I am thinking
Hi, When the washer is in spin mode, do you hear the motor running at all. It could be the lid switch has broke. I do not believe it will be a motor.
To test the lid switch, Remove the screws located on the back of the control panel on each end.
Lift the control panel and let it rest on the hinges. The lid switch is located to the left and has a three wire harness. Unplug the washer before you unplug the harness and put an insulated wire between the two gray wires (not the green stipe wire)
If you can jump this, turn the timer back into spin cycle and see if it starts.
Please let me know if it helps or if I can assist you further.
Vic
May 30, 2009 | Whirlpool LSR5132PQ Top Load Washer
Works then doesn't
The transmission would be very noisy if there was a problem.
Tilt the machine back and turn by hand, this will be stiff turn one way only, which is normal. if it feels ok remove the belt and run as normal listen to the motor for any problems if problem persists with out the belt on - likely cause is motor, I have a spare if you require.
Apr 07, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
