Question about Samsung SC-D86 Mini DV Digital Camcorder
Picture roll on lcd screen
I have a samsung vpd video camera and the picture on the lcd is rolling very slowly when im recording.the picture is fine when being played back after the recording.its very off putting and you tend to keep moving the camera up and down with the roll? any suggestions. i dont want to send it off to samsung repair centre they are crap!!! dealt with them before. cheers ian
Thick black line rolling up the recorded video of the TV
That is the camera not being in sync with the refresh rate of the TV. With consumer gear, there is really not much you can do about it.
Sep 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
LCD screen continues rolling
There is connecting ribbon wire between LCD board and main camera board, this ribbon wire is cracked and needs to be replaced.
Dec 10, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-SR42 LCD problem
fp-610 or 1-871-457-21 or old part number 1-871-457-11 is a flexible connector, runs for about $40 with shipping on ebay or web
Apr 26, 2008 | Sony Handycam DCR-SR42 Camcorder
Display screen is rolling
a few possibilities =
lcd damaged
main board damaged
or loose connection.
any of the three needs to be repaired.
sorry for the bad new :(
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
In Camera (Record) mode, does not show video at all, black screen
THIS IS YOUR CCD.. SAMSUNG IS VERY AWARE OF THIS BUT STILL CHARGES A ARM AND A LEG
Feb 06, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Picture rolling
the problem of your camera is the alignment...so try to adjust the two tape guide and two small screw near at the video head is you can open your camera..doing these you should be careful cause your to close to the head or you may damage it..adjust the small screw first slowly...if is not work then the tape guide...
Aug 09, 2007 | Sony Handycam CCD-TRV416 8mm Analog...
LCD screen isn't working.
Hello, the special flat cable connecting LCD panel with main board is broken. If you want I can supply you with further info (part number, etc.) at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Picture rolls on playback
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
Feb 25, 2018 | RCA CC617 VHS-C Analog Camcorder
No visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Sep 04, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Samsung SC-D86 Mini DV Digital Camcorder Logo
201 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
