Cannot install Canon Pixma MP620 drivers
On Connect Printer dialog:1. I connect printer to laptop with USB cable2. Dialog: "Printer recognized, wait for installation to complete ..."3. After 10 minutes, "Can't connect to printer..."
I reinstalled (for xp on Dell laptop) several times (as per pretty useless instructions) with latest drivers from the Canon website and get the same behaviour every time.
Has anyone experienced the same problem?
  • Anonymous Nov 25, 2008
    i have the same problem
    i am so disapointed with canon ,,,,,
    regards
    jo
Printer propperties/connections/add...
add a new Canon BJNP port
this solver the problem for me
Posted on Dec 13, 2008
I am getting an error message saying Incorrect port detected. The printer is designed to work with USB cables only. The current software setting is not set to USB port. In my printer properties dialog
Do you hear the connect/disconnect sounds when you plug the USB cable into your computer? If you do not, then the system is not recognizing the printer USB port.
Here is what I would do:
1. In the Devices and Printers section of the control panel, right-click on the printer icon, and select printer properties, then select the Ports Tab. Delete any ports connections for the printer. There could be several for the same printer.
2. Uninstall all Lexmark drivers.
3. Make sure that the printer does not show up in the Devices and printers under control panel. If the printer still shows up, remove the device by right-clicking on the icon, and select Remove device.
4. Reboot the computer.
5. Re-install the printer software. The software should detect the printer on the USB port.
Good luck.
Alex
Feb 14, 2015 | Lexmark X5650es All-In-One Inkjet Printer...
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
I just purchased a new printer the HP Photosmart 7510. When I try to add the device to my laptop, it asks me for a pairing code. It states that it may be found on the bottom of the printer or in the...
Any software related issues pl tell about your operating system, then it is easy to give better solutions by our team.
Dis connect the product to your laptop, go to control panel search for the printer software, if you found un install or remove the programme. Run driver CD,select auto run, let it run connect USB cable when device searching for the product, wait till completes, follow the dialog box, complete it.. shoot test page to print..Its normal process even if you are facing any kind of problems let give some more information about OS,printer connectivity,system permission etc..
Sep 04, 2012 | HP HEW CQ877A PHOTOSMART 7510 WIRELESS...
My HP Deskjet F380 all in one printer will copy but won't print
Switch off the printer,un install existing drivers(not to delete), restart the computer, switch on the printer, check whether system is recognized the printer?.. if not,try with another usb cable, no luck? problem with Logic card if available replace it or else go for new printer..
If system is recognized the printer, switch off the printer, run the driver CD.. connect USB cable when dialog box appears, do rest of the installation process. Shoot test page....Best off luck..
Aug 01, 2012 | HP DeskJet F380 All-In-One Printer
My printer is offline
do you have original CD with you? Un install the drivers, run the CD, connect printer when dialog box appears to connect check system recognized?.. yes do rest of the installation process.. check for the print..If printer not recognized, formatter faulty, buy new printer...
Feb 01, 2012 | HP PSC 1210 All-In-One InkJet Printer
Installing printer in Linux
Manually Installing a New Locally Connected Printer and Printer Driver When Ubuntu detects a printer it will automatically select a driver if the printer is recognized and a driver is available. To manually add a printer, begin by clicking on the New button in the Printer configuration toolbar. A Please Wait. Searching for Printers dialog will appear as the system is scanned for a locally attached printer. Once the search is complete, the New Printer Wizard dialog will appear including an entry for each detected printer. In the following figure, Ubuntu has detected an HP DeskJet printer connected to a USB port:
Select the desired locally connected printer from the list in the left hand panel and click the Forward button to select the appropriate printer driver. On the resulting screen select the printer manufacturer and choose the model from the list. Click on the Forward button to install the appropriate driver for the printer:
Once the printer driver matching the printer has been selected, click the Forward button and enter the optional printer description and location information. You should be returned to the Printers dialog where your new printer should be listed.
Once the driver is installed you are ready to try out the printer. In the Printers dialog select your printer, right click with the mouse to pop up the menu and select Properties. Click on Print Test Page to send a test page to the printer.
Aug 03, 2010 | Canonical Ltd. Ubuntu
How do i connect to a laser jet 1020 dell
If the printer is new out of box then remove the printer out of the box with the Data cable and the power cable with the disc.
Connect the power cable from the printer to the power jack.
Connect the data cable from the printer to the USB port in the laptop.
Once this is done turn on the printer.
The system will detect the printer and a dialog box prompts the installation of the printer.
Then put the DVD on to the drive and from the dialog box choose the location as the CD/DVD drive as a source from where to install the software. This will install the printer and the printer is ready to use.
else
install the contents of the CD/DVD by accessing and double clicking the drive directly.
Sep 16, 2009 | Dell Inspiron 1525 Laptop
Am having problem installing my hp laserjet6p printer
just check out the instructions its for both inkjet and laser printers. When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
To switch to a new printer that you haven't designated as the default printer in programs such as Word and Excel, you need to open the Print dialog box (choose File-->Print) and then select the printer name in the Name drop-down list box.
Feb 02, 2009 | HP LaserJet 6p Printer
How can i download the installer for my creative vibra personal webcamera
1. Do not connect the webcam to your computer before installing thedrivers. If you accidentally begin installation with the webcamconnected, the Found New Hardware Wizard dialog box appears. Click theCancel button.
2. Then download this updated driver pack. It is azip file you must unpack to a folder.
http://blog.benjarriola.com/Vibra.zip
3. Click the names of the drivers and applications you want to install on your computer.
4. Follow the instructions on the screen to complete the installation.You may be asked, after an application is installed, if you want torestart you computer. Do not restart your computer until all thedrivers and applications are installed.
5. Connect the webcam's USB cable to an available USB port on your computer and wait for Windows to detect the device.
6. When the Found New Hardware Wizard dialog box appears, selectInstall the software automatically (Recommended), and then click theNext button.
7. When a Microsoft warning dialog box appears, ignore the message and click the Continue Anyway button.
8.Installation will complete.
9. Check the image in the Video preview pane of the Vibra Webcam CameraConfiguration dialog box. If it flickers or displays a series of darkbands, click the Cancel Flicker button.
10. Click the Finish button, and reboot if necessary.
When you boot up, you can check the Device Manager (ControlPanel > System > Device Manager). Click the plus(+) sign next to theImaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
Dec 23, 2008 | Creative Labs Vibra Webcam
I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program...
To install the printer do this:
Nov 23, 2008 | Office Equipment & Supplies
928 people viewed this question
jasbo
jasbo
