Question about Garmin GPS
Alert quiet on my garmin forerunner 305 it used to be loud
  • duketheduck Mar 11, 2009
    The alerts on my Garmin Forerunner 305 is very quiet and its hard to hear during interval training.
SOURCE: GARMIN 305 Forerunner wont transfer data to PC
For Pc users:
Go to Garmin website Updates & Downloads, Training Centre for Windows software version 3.4.1, click on download.
I previously deleted all saved couses on Training Centre, but don't know if this is relevant.
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: Garmin forerunner 305
Will it start up whilst in the cradle, charging?
Mine did, but will not charge up off the cradle. Turned out to be a duff battery/connections due to water getting into the device!
F_P
Posted on Jul 08, 2008
SOURCE: My Garmin forerunner 305 will not turn on.
I have had the same problem. To fix it, I simultaneously hold down the "mode" and "reset" buttons for about 10 seconds. After releasing the buttons I power it up as normal. This has worked both times it has happened, and I got this fix from the Garmin website. My mileage totals are still in the history.
Posted on Feb 26, 2009
  • 84 Answers
SOURCE: how to set 10 mins running and 1 min walk breaks on 305 garmin
Training (enter) Work Outs (enter) Interval (enter) Time/Rest Time (enter) Enter 00:10:00 for time Enter 00:01:00 for rest time Make sure you have enough Reps set for your run. If in doubt set it very high (40) Scroll down and select done. You will have to scroll to this same page every time you want to use the 10's and 1's. Just cycle through the page with out changing anything and select done, you're ready to go!
Posted on Jun 08, 2009
  • 84 Answers
SOURCE: change Battery in garmin forerunner
Might not be the battery.My wife's was always powering off during runs. Then it would not power on at all. There was a connection inside that wasn't making contact. But first First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some brass fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps.Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker.Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs more that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag.Let the unit sit over night. In the morning remove the tape.
Posted on Jun 09, 2009
Hi. It is supposed to be a wake up alarm function in my Forerunner 305, but I can't find it (I really used that function in my old Polar). Where can I find the settings? Best /Fredrik
The only alert that comes close to being a wake up alarm is the Time alert function. Press Mode and then select Training. Select Training Options > Alerts > Time/Dist Alerts. In the Time Alert field, set the alert to Repeat (instead of Once or Off). Enter the time that you want the alert to sound in the Alert At field. Then press Mode repeatedly to exit the menu.
The manual for the 305 is available here http://static.garmincdn.com/pumac/984_OwnersManual.pdf . The time/distance alert picture is given on page 9. Links to additional documentation are available here https://buy.garmin.com/shop/shop.do?pID=349&ra=true .
I hope this helps.
Jul 04, 2011 | Garmin Forerunner 305 GPS Receiver
I have bought a new computer, windows 7. I cannot install driver for forerunner 305.
Glad to HELP YOU!
It's a well-known issue between Windows 7 and Garmin Forerunner.
Garmin company says it's a compatibility issue concerning the USB connection between the computer and the device and usually they recommend to be an Intel Chipset.
Try to download and install using the latest drivers available on their site on WIN 7 and Forerunner 305.m You have them ALL here and the USB driver was released this year and it's the last one on that list.
GOOD LUCK!
Mar 26, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
I cannot hear the alerts on my Garmin 305, is there some way of making them louder?
Unfortunately there is no volume control on this unit, but you could try making sure that the four small holes to the rear are clear from foreign bodies if any, sorry.
Jan 01, 2010 | Garmin Forerunner 305 GPS Receiver
How to set 10 mins running and 1 min walk breaks on 305 garmin
May 29, 2009 | Garmin Forerunner 305 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
