Question about HP Pavilion dv6000z Notebook
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
The blue LED light doesn't come on, or if it does, just for a moment to tease me and then fades. The computer is not charging, and I tried to replace the AC adaptor and that is not the problem because it still doesn't charge. HP says it's the motherboard and will be 250.00, and it is 2 years old, so it is out of warrranty. Any ideas?
  • Anonymous Feb 21, 2009
    when I turn off the laptop and then turn on again, it does return to 100%, nevertheless, the support said its the battery. I'm sure its a SW issue
  • Anonymous Mar 13, 2009
    Same problem i have to **** the wire a litte then the light comes on and then goes off in seconds. Tried replacing the wire but still the same problem
  • HP Master
  • 32,281 Answers
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Posted on Nov 19, 2008
My cap lock works, but the led light doesn't work on my HP dv6000 laptop.
Does your number light work when you toglle the number key?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | HP Computers & Internet
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
My hp Pavillion dv6000 looks like it wants to turn on but turns itself back off after a min or two. It does this process over and over without turning on.
Unplug AC & battery. Then, unplug the cell battery right at the memory compartment (wait for at least 10 min).
Plug everything back in. Laptop should be back to normal.
It works for me.
Cheer
May 12, 2010 | Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Pavilion dv6700 AC Power. My DV6700 performs perfectly on battery, but will not charge the battery or run straight off AC. AC Adaptor, Batteries and AC jack have been tested in fine working order. Any...
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
Dec 29, 2009 | HP Pavilion dv6000z Notebook
HP DV6000 Not working correctly when plugged into mains power
it has to do with the power pack mean the charger,It is most likely that you are using the wrong adaptor, get original power adaptor for your laptop and can assure you will get it worked.
Jul 16, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
1,720 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
