Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
How do i get a Comcast HDTV Cable box to work with my sony Bravia Dav-HDX279w so I can enjoy my surround sound while watching cable. right now only the tv speakers work.
  • Anonymous Nov 29, 2008
    My new bravia and surround sound was working until i hooked up the new hd cable box. Help!
  • Anonymous Dec 08, 2008
    It only works when i use the DVD player, but not the box. Any ideas?
  • 21 Answers
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Posted on Feb 20, 2009
    Problem Solver:
  • 18 Answers
You will need to connect the cable box audio to the TV with either a coaxial or optical cable. The "RCA" cables do not support surround sound.
Posted on Dec 28, 2008
My Sony DVD plays but there is no screen on the Sony Bravia TV. I hear the movie but no picture. The HDMI cable is plugged in. Why can't I get no picture? The TV is blank.
Make sure that you are plugged to the input of the TV and not the output. The other thing is it could easily be a bad cable. Check to make sure all cables are pushed in all the way as well. I know that sounds stupid but those are the little things that drive us all crazy but usually fix it. If none of this works let me know.
Jun 12, 2011 | Sony BRAVIA® DAV-HDX279W Theater System...
I've had my Sony Carousel CD player wiorking with DAV-HDX279W home theater system before. I used the TV/Video mode and it played. Now it doesn't. I can't find any setting that might have changed. ...
make sure the input is set to( analog in) on the stereo --this will enable the red and white jacks----it might have changed to digital which would enable the optical and coax jack--
Sep 05, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Aug 03, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
On my SONY DAV-HDX279W, the module that runs the rear speakers turns itself off after just a minute or two. In other words, my surround sound system won't deliver surround sound. Is this a short? Any...
are you using the speakers that come with it? its not typically recomended to use speakers not included with your htib system due to the diffrence in nominal ohms. however if you are using the original speakers check to see that the positive and negative wires are not touching. also check to see that there are no loose or cut wires if you have taken all of these precautions then most likely your unit is over heating due to prolonged use
May 24, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
No sound through Bravia speakers after BOSE removed.
Did you ever have audio through your tv before?
It's likely that your Comcast cable box was connected directly to your Bose system, and not your television.
You'll need to check the connections from your cable box, to your television.
Mar 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
I have a sony hdx279w surround system, the center speaker is not working? I can not figure this out. I also...
you have to go to system menu and press up and down until "DEC.MODE" appears then press the right arrow press up n down again put it on "PRO LOGIC" that should work it did for me .good luck!
Mar 10, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Cannot hear regular tv through speakers
you need to purchase either rca cables or optical cable
Jan 18, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
796 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
