Question about Dymo LetraTag QX50 Thermal Label Printer
Too much tape...
When i print my labels, there is too much paper coming out on both front and back. Like my margins were set wide. The printing might be just a couple of letters, but the tape is 3 inches long.
  • 1 more comment
  • Imjetta Dec 20, 2008
    Too much tape coming out. Is there a setting that got messed up or something??
  • Anonymous Dec 30, 2008
    same problem. The tape is so long. The message is only a couple of letters and the tape is 4 or 5 inches long. I keep getting an error 3 message when I try to change the length.
    HELP
    HELP. Same problem
I was able to fix my problem. Please erase my email from your list.
thanks
Posted on Nov 19, 2008
Label print problem making in MS word
You need to set up the paper print size for the Cannon. It may be a different print height and width.
Feb 27, 2014 | Canon LASER SHOT LBP-2900 Printer
Problems printing labels
may u should the paper size setting
Jun 01, 2010 | HP (139545-001) (139545001)
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Label Printing Problems
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Dec 12, 2007 | HP Officejet 4215 All-in-One Color Photo...
Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Oct 15, 2007 | Samsung ML1740 Laser Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
491 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
