Question about Pelco ES3012 5MLZ30PW Esprit High Res Black and White 30X Zm Presets Mount 120/230VAC
Camera will pan to an area but will not stay there.
The camera can be run through it's test mode fine but to pan to an area and stay there it will not do that. It returns to the preset position.
  • adpatten Nov 19, 2008
    The camera system we have refers to it differently but the home setting is for 2 minutes and those are all turned off.The camera throws a alarm as well. Thanks
  • 186 Answers
Program preset 95 to access menu and turn off home to preset, set it to none. or set inactivity to 0 mins. job done.
Posted on Oct 17, 2010
    Problem Solver:
  • 5 Answers
Read the manual, it is caused by menu setting" Power up Done" or "Park",
Power up done- What you want PTZ Camera to do after it's config done,
Park-- what you want it to do after xx seconds inactive.
Posted on Aug 06, 2009
    Problem Solver:
  • 8 Answers
Most PTZ cameras have an "inactivity" setting. If no command inputs are entered into the keypad for a programmed amount of time, typically between 30 seconds - 5 minutes, the camera will return to it's pre-set position. You should be able to turn this off in the camera programming. A good way to test to see if this is the problem would be to point the camera to an area, then make very tiny adjustments to the direction every 2-3 seconds. If the camera does not go to the pre-set, then inactivity is turned on. Also, point the camera to an area and time how long before it returns to pre-set. If it is the same amount of time on every occasion, this would also indicate that inactivity is turned on.
Let me know if this does not work, or if you don't know how to access the programming menu - steven.burman@commandtechnologyassociates.com
Posted on Nov 19, 2008
It loses power and stays in 2nd gear. If I turn it off and restart it, it's fine for awhile
Depends on car. Sounds like it's in limp mode. Computer may need to be reflashed
Dec 11, 2014 | Cars & Trucks
On program mode my maxxum 500 stays at 2000 speed and 22 f...no matter what the lighting condition what should i do
I have a Minolta maxxum 400 sl that's in like new condition, only has had 10 rolls of film run through it. Would you like to buy it ?
Sep 14, 2014 | Minolta Maxxum 5000 35mm SLR Camera
Ford telstar 94 auto
Lets try this again. Computer just shut off near the end of my explanation. Once more, these computer operated engines in vehicles now are just plain finicky. No signal from a faulty sensor will not change the situation. When first start, the computer puts it in cold start mode, putting more fuel into the engine so it will start and keep running. If the faulty temperature sensor is not sending a warmed up signal to the computer, it stays in cold start mode, dumping excess fuel into the engine when warm and it won't run right. First thing I'd do is check and change the temperature sending unit. Ya gotta be smarter than the computer to figure these things out. Mainly just some common sense works too. I still haven't figured out why my computer shut down a few minutes ago. Like I'd pushed the off button. It's a computer, garbage in, garbage out.
Jun 25, 2017 | Cars & Trucks
Removal of an oil pan on 1997 gmc silvarodo truck,2500 liking oil from oil pan gasket
It's quite rare for one of these pan gaskets to leak so before you take it off I would suggest thoroughly cleaning the entire pan and then going for a short test run then carefully inspecting the pan area again to see if you can pinpoint the exact source of the leak. Often I see the oil filter adapter or oil cooler lines [if equipped] leaking which can cause oil to run down the side of the pan and make it appear as though the pan gasket has failed. Sorry I don't have the procedure for removal of the pan but I rarely have to take one off for a leak. Hope this helps and good luck!
Mar 18, 2011 | 1999 Chevrolet C/K 2500
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Water running from under the refrigerator
experts say that there may come a time in a fridge's life where you have to open the back panel and clean the condensation coils. When they go in cooling mode, you get frost on the outside of the firdge (on the coils) because of the dirt. When the fridge goes off cooling the frost melts and of course, comes out under the fridge. Still is your fridgea normal one, or one that is connected to a water pipe?
Jan 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
CAMERA WILL NOT TURN ON
I had exactly the same problem I seem to have solved it by holding down the shutter button and then pressing the on/off button. It powered up and the lens stayed out. It was not auto focusing, so I placed it into manual focus and ran it back and forth in manual focus mode. (The circular button on the back adjusts manual focus by pressing it to the right or left) I suspect it's part of the start up self test that checks to see if the auto focus system is working, if it fails it shuts off. I think I stumbled onto a override of sorts by the button combination. Running the manual focus seemed to help. I do have a small black area in the upper right of the screen that gets no light - a dark spot. I store the camera in my pocket, I wonder if some pocket fuzz got into the camera somehow...
Oct 24, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Pelco ES3012 5MLZ30PW Esprit High Res Black and White 30X Zm Presets Mount 120/230VAC Logo
234 people viewed this question
Top Pelco Home Security Experts
bobby euell
Level 1 Expert
Leon Peach
Leon Peach
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
