Question about Sony KP-53S65 53" Rear Projection Television
Sony KP-53s65 Tried using the DVE -DVD alignment disc to improve the picture.. All images are sort of dim. When I try to boost brightness, color becomes over saturated. How do I determine if the projection bulb(s) need replacement and if thats the problem? What should the ideal repair cost from a reputable service?
  • gene perciavalle Dec 11, 2006
    This comment may show my ignorance and naivete', will dusty lenses perform like an aging TV tube? In fact does this unit have a TV tube or projection lamp? Aside from the simple solution of cleaning the lenses carefully and possibly the mirror, how do you determine if the Tube or Lamp are dying or beyond the salvage point?
    I have been fairly good over time at adjusting the Convergenece with the "user" control, however the picture edges clearly show convergence alignment issues that I cannot resolve. Could using the SONY "Diagnostic" controls code access resolve this, if at all? Or did I make a poor purchase decision when I bought it some years ago and failed to understand the importance of convergence?
    Thanks
  • 65 Answers
Take the back off oh unplug it first and then read the label that says no user serviceable parts inside its kinda like the tag on pillows the three delta lenses can be cleaned with a soft cloth dampened with windex they are an optical grade of plastic like the screen so all those caveats apply if you are really brave you can take the lense assemblies off and clean (gently the concave) portion of the top of the crts they are filled with coolant and should be treated with care if you are really brave use windex on the plate glass mirror if you are nice to your tv it will look real good when you get done it will look even better if you know how to refocus the focus block and the screen controls all the home theater dvds wont make up for zen and the art of projo maintenance
Posted on Dec 09, 2006
I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Apr 04, 2010 | Sony KP-53HS30 53" Rear Projection...
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv gets bright and then get dim and dose this the entire time tv is on
If you watch a DVD, does the picture also flash? If not, it might be just the TV signal. Are you using a cable/satellite receiver? If so, check it's connections. If anything viewed on the TV, using different inputs and a different cable/wire, is flashing, it is a problem with the light engine or color wheel, if the TV is DLP.
Oct 17, 2008 | Sony KP-61XBR48 61" Rear Projection...
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
Screen goes light and dark
sounds like you have bad caps in video area. Will need repair by experience tech.
Sep 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Half the screen has ghost image (not focused)
Replace the convergence ICs. They are located on a large aluminum heat sink with STK numbers stamped on them. They cost about 10.00 each. They have to be soldered in. Let me know if you need anything further.
Aug 23, 2007 | Sony KP-53S65 53" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Jan 03, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
298 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
