Question about Sanyo DS24424 24" TV
Cannot navigate MENU on Sanyo DS24424
When I press the MENU button on the remote, I see the menu on the screen However, I cannot navigate the menu no matter what buttons I press on the remote. Using the volume and channel buttons on the front of the TV don't move through the menu either. Has anybody else seen this problem
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
  • 2326 Answers
SOURCE: Sanyo DS24424
The only way to do it will be using the original remote.
Click here to find the original remote control.
Good Luck.
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: can't shut off closed caption no remote
Have you tried unplugging the entire device and plug it back in 15 secs later.
Posted on May 17, 2009
SOURCE: Sanyo tv channel stuck
A POSSIBLE solution. I have the same it used, but it's in good condition.
It was stuck on a channel. I went iinto the menu and fiddled with the channel programs and "deleted" the channel and now I can freely change channels.
By the way, I could use a manual for this one?
SOURCE: Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Posted on Sep 30, 2009
I have a 42 inch Sanyo Harv with no remote how do I get in the menu
Look at the back or the side of the TV, you should have the standard buttons: power, menu, volume + volume - and input depending on the model, use the menu button to get to general menu and volume +/- to navigate
Mar 23, 2015 | Sanyo Televison & Video
How can i find the codes to program the remote
Usually a universal remote has a list of supported codes for tuning the remote when you start it up. Some remotes have automatic settings so you only press one button to get the right code setting.
Aug 22, 2014 | Sanyo 31" Tv Flat Screen W Larger Back...
You may have a manual MENU button on the side of the TV that can give you navigation through the MENU windows on your screen. Check the TV or manual.
Jun 01, 2014 | Sanyo DP26649 26 in. TV
How do i change the tv from cable to regular tv with out remote
Does the TV have a menu button? It could be on the front or on the side with other control buttons. If it does, you can navigate through the On-screen Display with the Ch (up/down arrows) and Vol buttons (left/right arrows).
Press Menu and go up or down to Setup. Then press the right arrow to enter the submenu. Use the right arrow to rotate through the list of tuning bands (TV, cable, etc). Press Menu to store the change and then press Menu repeatedly to exit the OSD. (This applies if the incoming cable signal was on coax and you are switching to OTA signals. If you have a cable box that was connected to a different input and you are adding OTA via a coax connection between the antenna and the TV, press Input instead.)
This is based on a Sanyo that I know. Please check your manual or provide your model for additional information.
I hope this helps.
(if the TV doesn't have a Menu button, then you will need a remote that matches the feature. I recommend you consider one with an Input or Source button if you might need to change from TV to DVD or other sources. The remote should be one that was programmed at least 6 months after the TV was released - that will be more likely to include the codes for your TV.)
Mar 09, 2011 | Sanyo Televison & Video
Sanyo 32469 can not turn off the closed caption do not have original remote what should i do
Try the on board menu on the tv to see if you can gain access, if not the original remote will be required. One possible solution is to go to a tv repair shop to see if they might have one. They usually keep a box of used remotes.
Jan 01, 2011 | Sanyo DS24424 24" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Sanyo DS24424
Good Luck.
Apr 26, 2008 | Sanyo DS24424 24" TV
How do I remove the closed caption from Sanyo Model DS24424 without a remote control
If the front panel has the menu feature, you can do it by pressing it and use the Volume/Channel buttons to navigate through the OSC screen until you get to close caption to turn it OFF.
Apr 25, 2008 | Televison & Video
Unwanted channel display in middle of screen
TO REMOVE CHANNELSscreen13.gif 1. Press the MENU button on the remote control to open the OSD.
2. Press the Navigation (UP/DOWN) buttons to select the Setup menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to select MANUAL SEARCH.
5. Press OK to select.
6. Select the channel you want to delete from the channel list.
7. Press the Navigation (LEFT) toErase Channel.
8. Press EXIT to close the OSD.
Feb 29, 2008 | Televison & Video
Sanyo DS24424 24" TV Logo
59 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
