I have a Dell XPS 600 system that works great, but has recently had problem connecting to the internet. I show an organge light where the ethernet cable goes into the port adapter. My understanding is this is integrated into the motherboard. I have tried replacing the cable, the cable modem works fine b/c it works on my laptop, I do not have wireless, or router. I have reseated the adapter, cable, and was checking the duplex you have any ideas? If I need to replace it what is the best way to do that? There are 2 other USB connecters on the same adapter so I am suspicious that only the ethernet port is gone. Thanks for your help. Suz
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    It is highly unlikely you have a hardware failure in the network interface, or that your network adapter is faulty because a light is orange and not green. The orange light can mean many things depending on your adapter. The only light you need to be concerned with is a RED light.
    What type of connection to the Internet do you have? Cable Modem, DSL, ADSL?
    And, what do you mean by reseated? Did you remove the side panel, extract a device card that they eithernet cable connects to and then reinsert this? If so, your cable is not connected to the integrated Network Interface it is plugged into an Adapter *Card*.
    I can assist you further in understanding what you have so when you speak with your internet service provider you have a better vocabulary of terms and can solve your connectivity issues, if you have any.
    But first using the PC in question go to this internet address or use your laptop.
    Pick a destination that is furthest from you and run the test. Then post the speed results back to me in a reply.
  • 25 Answers
SOURCE: Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
Posted on Dec 28, 2007
  • 143 Answers
SOURCE: Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
Posted on May 21, 2008
  • 45 Answers
SOURCE: limited or no connectivity to
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from to save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Posted on Oct 08, 2008
  • 538 Answers
that would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Posted on Oct 22, 2008
  • 236 Answers
SOURCE: Have internet connection but browser won't open
try pinging from the problem pc.
  1. Go to START
  2. Go to RUN
  3. Type in CMD [hit enter]
  4. IN the dos window, type : ping
  5. hit enter.
If your pc can reach google, it will ping back 4 successes
I would install and run spybot from That is a spy-ware checker program and is free.
Post back with results.
Posted on Dec 17, 2008
What cord connects an xps 600 to the internet
Via ethernet cable called CAT5e, using RJ45 connector.
It goes into your LAN/Ethernet port on the rear of the machine.
Take care!
Sep 15, 2012 | Dell XPS 600 PC Desktop
I don't know what cord connects a xps 600 computer to the internet
The internet jack fits in only the one jack available. If you have a modem card that jack will be to big to fit.
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
This is Dell Support >XPS 400 desktop computer > Service Manual,
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
Dell XPS M1530 Ethernet Issue
change power option to maximum instead of dell recomended
Feb 04, 2010 | Dell XPS M1530 Laptop
Dell XPS 600 beeping noice
there are 2 things that can cause that, memory failure, or mother board, cheeper route to go would be replace your memory first, and see if that corrects the problem, if not then, check anything new you installed inside such as video card, lan cards, of something like that, if that doesn't work you need to have it looked at and possibly the mother board replaced,
Jun 22, 2009 | Dell XPS™ 600 PC Desktop
XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
Xps reformat
those question marks only indicate your system is not showing drivers for that hardware... last time I reinstall the os on a dell system dell made it a little bit tricky to reinstall the drivers... if I remember correctly you need to run the software on the cds to install the drivers (don't try to install the drivers with the windows wizard as probably the drivers are nicely packaged in the cd.) so look for some setup.exe application on the cd's you may have.. (assuming those are the cd's that came with your system) run it and follow the instructions.. from that point it should be straight forward.
if you don't have the cd to your system here's the driver download website from dell for your system
(check if it is your system first)
download what you need first and don't run everything at the same time. install one at a time and restart as prompted and then move on the next driver installation, until you get all the ? marks out of device manager.
good luck!
Oct 02, 2008 | Dell XPS™ 600 PC Desktop
Problems connecting to internet with Vista
CLICK LAN SETTINGS make sure you have it checked to automatically detect settings
then click setup follow instructions
restart system
second option
If you have the internet icon on your taskbar right click then click wireless connections see if any show if so highlight and click connect
if none show on left side of same page click refresh network list you may need to do this a few times then when you see a connection highlight click connect
let me know if these solutions help
Jun 18, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
