Question about Cuisinart DCC-1200 Coffee Maker
Seems clogged After overflowing the filter basked, I tried cleaning the unit. It tries to work but not much water is comming thru to the shower head. I need further instruction on where and how to clean overflowed grounds.
  • marg175 Nov 21, 2008
    I think someone put very fine grounds in the basket and probably didn't push the basket all the way down which resulted in a clogged coffee pot. I tried using white vinegar and water but much steam and very little water is coming through. It takes as long to get 4 cups of water through as it normally takes to brew 12 cups. Could I use dishwasher detergent to dissolve the backed-up grinds???
The problem may be caused not by a check valve in the inlet hose. This little gadget, about an inch inside the heater end of the tube, allows water to flow into the heating element but not back -- unless it's broken. This hose is the one closest to the outside edge of the bottom.
I'm sure *someone* must sell a replacement part, and I'm in the middle of that search. But I did get an older, broken coffeemaker from my brother (another member of "the Slow Wastebasket" society!
I was able to disassemble my Model CBC-00PC2 using a standard Torx 10 screwdriver. However when I tried to take apart an older model, DCC-1200, I found that it used the security version of the Torx 10 screw: it has a tiny nipple (correct word?) in the center of the screwhead that prevents a standard Torx driver to fit. I was unable to find the correct screwdriver and a security Torx bit is too thick to fit, so my brother and I resorted to brute strength to pop of the bottom.
The only other problem I had was that the older hose was a bit brittle and both the older and newer ones had sort of welded themselves to the aluminum heater element tube. Luckily, there was enough extra length and I was able to make it fit -- barely! I lost one of the little metal clips so substituted a tiny cable tie.
Everything seems to work. Oh, the only reason I knew about the check valve is that I previously disassembled the thing to see what was wrong and I found something (probably a piece of the valve!) floating around.
Hope this helps.
Posted on Nov 29, 2008
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
    New Friend:
Disconnect the coffee maker, take carafe, filter and filter holder out. Lie the coffeemaker down over on the the side of the sink with the back of the coffee maker facing away from you, the top over the sink, dip stick removed and facing down towards the counter-top. Look inside the reservoir and you should be able to see the hole where the water enters the heater. The coffee grinds get stuck in that opening and cannot get out. Solution: I used two plastic straws joined end to end. Then used water from my mouth blown in through the straws to flush out the hole. The water flushes the grounds towards the sink. After a few mouthful flushes, shake the coffeemaker and more grounds begin to emerge. Repeat till the hole is noticeably clearer. A headlamp or bright flashlight helps immensely to see the intake hole with (before) and without the grounds (after). Reassemble and run water through the coffeemaker. I was able to get 5 cups out in 4-5 minutes. Previously it took 20 minutes.
Posted on Feb 22, 2013
I have the same coffee maker - only a few months old - and same problem. I forgot to put the carafe back under the machine one day, turned it on to brew, and the coffee grounds backed up inside, getting the reservoir dirty.
I don't think it's a broken part - I think it's just clogged, like toilets or drains get clogged. I'm trying to figure out a way to flush out the grounds in there. Vinegar is good for calcium buildup but doesn't dissolve grounds, obviously.
Posted on Jul 19, 2010
  • Mary Taormino Oct 21, 2010
    How did she fix it? I have the same problem. It now takes forever to brew a pot of coffee and the machine makes a sputtering sound as it brews. I've tried vinegar and water 4 times to no avail. How do I fix it?
My Marey tankless water heater will not ignite for the shower, but will forthe faucets. Have changed batteries, cleaned the filter and had the showerhead cleaned. Local plumbers will not do...
Most on demand or tank-less units require a minimum flow rate before the unit will fire up, they designed them that way so small water leaks (drips etc.,) keeps the unit from going on needless;y. Try opening the shower hot water fully and see if it comes on, If it does, try closing it slowly to see where it shuts off. Make sure your shower head is clean and not blocked with calcium, which will restrict the water flow. You could also try changing the shower head to one that allows more gallons per hour flow rate. Also make sure the cold inlet and hot outlet valves on the unit are fully open and the diverter on the shower is fully open as well.
Mar 24, 2015 | Water Water Heaters
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
Low water pressure - I removed the shower head from the hose. The hose from the wall to the shower head has a filter. How do you change or clean out the filter? I suspect the filter is...
unscrew the the big part of the shower head. if it is difficult it may have been put on there too tight. lowes has replacement filters.
Dec 04, 2010 | Home
Filter seems cloged
Have you tryed soaking it in viniger will clean shower heads.
Do you get a good stream of hot water through the shower arm with the shower head off. Take it off and make sure shower valve is suppling hot water.
Mar 06, 2010 | Water Pik & Wallmount Showerhead
Our Bunn DBC has severely reduced flow in the left unit. There are over 14,000 brews done on it. The fill rate of 53 oz/min is now at 12-14 oz. Do I have a major blockage in the water distribution system....
remove shower heads and clean. It's the 4 inch disks above the brew funnels. You can use a tooth brush on the holes if you can't remove them. try brewing to check if that helps.
Note; if it is a clogged water filter on the main water line then that should be replaced as most filters only last a year. Recalibrating it without the filter change will allow you to brew but will overflow again when the filter is changed. (a change out by the landlord whom may not notify you will cause an overflow, another service call, plus clean up of coffee.
Jan 15, 2010 | Bunn 34600.0004 Coffee Maker
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Apr 05, 2009 | Home
Cuisinart DCC-1200 Coffee Maker Logo
2,593 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
