FixYa.com
Tags:
Brother LS-2125 Mechanical Sewing Machine
Button hole
posted by roskoe on Dec 08, 2006
when in b, material doesn't move. all other sewing works fine. Tried differnt kinds of material and thread. machine is new and worked fine with first button holes, next day didn't work.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 03, 2007
Not Rated (0)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1042 votes
If I remember your machine is a single dial machine without a stitch length adjuster but correct me if I am wrong, if the mnachine was making buttonholes previously and now suddenly does not work it is probably something you may be doing different, a thicker fabric will make a difference, if you do have a stitch length dial set the stitch so it is not too close.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Sewing Machines problems?
I cannot get the needle to...
When I lower the needle in to... Answer This...
upper tension too tight ,
upper tension too tight , the... Answer This...
euro pro Model 361 tension wire
Hi, I just purchased the above... Answer This...
espanol no quiere coser mi
espanol no quiere coser mi ... Answer This...
water issue
i am aware of Stanley Meyer's... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
