Question about GE Profile JGS968 Gas Kitchen Range
After self cleaning, Range trips circuit breaker when using convection
I've had the range for two years and it's worked perfectly. After just recently running the self-cleaning for the first time, I now cannot use the convection function without tripping the circuit breaker of the circuit it's on. All the other functions work fine without tripping the switch; I can cook on the burners and even bake without convection. Can anyone help me?
    Sergeant:
    Champion:
  • 310 Answers
Self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
Range starts beeping out of the blue. Cannot turn off or reset. Have to shut off breaker to range. I have had entire module replaced three times.
Hello Hugh Casper - If you have already try resetting the range by either unplugging it or flipping the household circuit breaker off and beeping continues then contact a professional to move forward accurately. The unit may be experiencing a wiring failure, communication error with the EOC or the EOC itself is not working correctly.
Dec 18, 2012 | Frigidaire Gallery 30" Self-Cleaning...
After a power outage my oven stopped working. Stove top is fine.
Have you checked your 220V circuit breaker? It may have tripped and just needs to be reset.
Oct 18, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Just installed Fridg. Gallery convection range
The PF code stands for "Power Failure". This code will appear whenever the power is disrupted to the range. Pressing the cancel button on the touch panel should clear this code. Now it sounds like there is either an electrical short on the range or a problem with your GFCI electrical outlet/breaker. There is an internal fuse that might have burned out inside the range to prevent further electrical damage or the ERC/touch panel may have shorted out. The problem is if you start tinkering with the range and it is brand new then you might void the factory warranty by trying to repair it yourself. I would leave it unplugged and call the manufacturer or the place that you purchased it from and describe your problem. There might be a recall on that model range or a problem that they are aware of. You also might want to try plugging a couple other appliances into the SAME electrical outlet plug that you used for the range and see if the breaker/GFCI trips. If it does then the problem might be with the electrical plug or circuit. A bad plug or circuit can cause damage to an appliance(like the range) so be careful with any other appliances you use to test the outlet because they could be damaged also if the circuit or plug is bad.
Apr 17, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
We self cleaned our Bosch oven yesterday. Now the
I would check the following because during a self cleaning cycle a oven gets very hot and draws alot of power and this could of happened
Fuse/circuit breaker
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirpool Range suddenly tripping the circuit breaker
It could be one of the elements is shorting out causing the breaker to trip. Try using one burner at a time to see which one causes the short.
Aug 21, 2009 | Whirlpool RF262LXS Kitchen Range
Ge electric range ahas no power, circuit breaker wont reset.
Unplug the range and try to reset breaker. If it holds, you have a shorted element or some kind of fault in the range. If it won't hold in, change breaker
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 04, 2009 | GE 30" Self-Cleaning Freestanding Electric...
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
GE Profile JGS968 Gas Kitchen Range Logo
597 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
