Question about Audiovox CDM8910WW
I went to go and charge my phone but it failed.
I went to go and charge my phone last night. When I did the red indicator light came on like usual and then it turned green and stayed like that. I unplugged the chrger to try and turn the phone on because it wasnt completely dead and all that happened was the red indicator light came on then the green for about 4 seconds then it turned off. I tried all day to see if it would kick back on, I even tried removing the battery for about 20-30 seconds, and still no luck, HELP ME!!
I have been made aware that the charging mechanism in the breaks off because it is made of plastic I was told it was a known problem but some stores will denie it and try to get you to you your insurance to get it replaced. For m that is a additional $50 charge and my phone is still under warranty.
Posted on Jan 09, 2007
My HBS 730 LG Stereo Bluetooth head set doesn't seem to come on. It seems not to charge up according to its indicator light.
the rechargeable battery has died and usually not serviceable by the consumer .check with a phone store .
Dec 08, 2015 | LG HBM 730 Bluetooth Headset Wireless...
LF tracfone won't turn on
Take it to a phone sales location and see if they have new battery to fit .
Sep 26, 2015 | LG TracFone 600 Cell Phone - TF600GP4
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
What does it mean when the light at the top of the remote is red instead of green?
The red indicates low battery. The batteries are estimated to last around 2 years at that point or later the battery will weaken and the red light will show up more often. In some rare cases the red light will not go away even with a fully charged new battery, in that case there may be something wrong with the charging circuit inside the remote that gives feedback on the battery's charge. You can either live with a false reading of the battery level and charge the remote nightly OR you can send it to RTI for a repair.
Nov 12, 2009 | Rti Technologies Rti T1 Remote Control
Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Mar 11, 2009 | Dell Latitude D600 Notebook
This started last night, my battery indicator
The red or amber flashing lights indicate a bad battery. The Dell battery warranty is only for one year and the D600 has been out for a number of years. You should replace the battery. You can use the laptop as it is as long as it is connected to AC power.
There are several places to buy replacement batteries. One is www.bixcomputers.com. If you do a search on the web you should be able to find other sources.
Good luck and I hope this helps, even if it isn't good news.
Feb 28, 2009 | Dell Latitude D600 Notebook
Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Sep 13, 2008 | Samsung WEP500 Wireless Headset
Battery light
This is pretty common and not necessarily a problem. Red means that the battery is not completely charged. Since it was charging all night, it most likely almost fully charged - say 99% or so. It's not really an issue as long as your battery icon has all the bars and the phone holds the charge for a normal amount of time. If you find that the charge lasts for less time than it should, you should probably replace the battery. My phone, for example, does this every so often and then will charge normally the next day.
Dec 05, 2007 | Motorola Mobility RAZR V3
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Audiovox CDM8910WW Logo
129 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
