Question about Kenmore 53642 / 53644 Side by Side Refrigerator
ICE MAKING NOT WORKING ON MY KENMORE SIDE BY SIDE
Hello.
About 3 weeks ago my ice maker stopped working. Up until than it worked fine making ice as needed. The water dispenser still works. Can you advised what might be the problem? Is this something I can fix myself or do I need to call a technition?
  • 706 Answers
Hello Heavensentme..
Since you pointed out that you don't have a restriction that limits water flow to your fridge.. then you may have a bad inlet valve that allows that same water to refill the ice tray or.. the switch that senses the ice bin is full is stopping ice from being produced.. The motor that rotates the ice tray may also be defective.. .. If possible,, can you empty your freezer compartment and let it thaw out and then try a fresh start so that you know you don't have any ice build up that is stopping the ice tray motor from rotating or the inlet for water isn't frozen? Otherwise.. they aren't that complicated but you kinda have to know what to look for and what to not touch in order to repair them.. Not sure this helped or not but hope so,,,
Regards
Rick
Posted on Nov 22, 2008
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice build up on back wall of freezer
You need to replace the heating elements and defrost timer relay. Had same thing as you 6 months ago. The lower one is probaly blown but replace all 3 parts or youll continue to have problems.
Jun 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
159 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
