Question about RCA HD52W59 HDTV Projection Television
My colors are out of alignment, I can actually see three different ones they are about an inch apart on the screen and there are 3 color lines draped across the top. I get a high pitched squeal, it has had the squeal for a while but it would come and go, now it is constant.
  • 4 more comments
  • fisherking27 Nov 19, 2008
    the other thing is that it looks like the picture is bowed in on all four sides
  • fisherking27 Nov 20, 2008
    Thanks for the reply. Do I need to remove the fuse to check it. Is it something I can get locally? Is the fuse marked so I can identify it?
  • fisherking27 Nov 22, 2008
    Thank you very much, the 75 cents I paid for the new fuse kept me from missing the game and buying a new tv.
  • fisherking27 Nov 29, 2008
    New problem, it keeps blowing.
  • fisherking27 Nov 30, 2008
    Yeah, I forgot I got so caught up in the tv working again but I did it this time
  • rcspotts Dec 06, 2008
    My TV (HD52W59) blipped while I was watching it and now it looks as though the colors have seperated from each other. I tried to switch the feed to video and when the screen is black you can see three color lines (blue, red, green) seperated at the top of the screen.
    Genius:
  • 1,030 Answers
Convergence. very common. First question when you go into the customer menu under setup do you have the convergence option. If you do not suspect the convergence fl231 fuse problem. i hove wrote instructions under the tips and trick section. The bowed picture and line definatley indicates a loss of convergence power. There are three seprate cuircit boards that controls this convegence power, convergence amplifer and the small signal board.. the small signal board would have to be replaced by tech. as there is special equipment requird. the other two you can do. If you have convergence option try the autoconvergence option and watch to see what it does
Posted on Nov 19, 2008
  • Willie Howell Nov 20, 2008
    do you have the convergence option in setup menu of customer menu. I wrote detail instruction on the poblem. look under tips and trick under my profile to make sure this is your problem
  • Willie Howell Nov 30, 2008
    did you resolder the flyback connections STEp 7 in the instructions. this is a very important part. when i first discovered this problem. they would leave and come back on me. Made customers very mad. i started resolder connections and i dont think i have got one back on that fuse repair. when a fuse blows something is loaded or loose,
Picture shows 3 colors on everything.example.if there's a hand.there's 3 hands and each is a different color Blue .red.green
There are actually 3 projectors inside, each handling one of those three colors which, together, make all the other colors. This is called "out of register" where they are aiming slightly differently. These need to be adjusted.
Jul 31, 2014 | Televison & Video
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
Green tint to screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2010 | Hitachi 42V710 42" Rear Projection HDTV
On the lower 1/2 of the screen on my panasonic 53 inch rear projection tv the colors are out of sync
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Televison & Video
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 07, 2010 | Televison & Video
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Green tint on Samsung Television
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
Automatically:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
1) MENU
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
http://resources.jvc.com/Resources/00/00/96/52105ien.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Color alignment is off
i also have the exact same problem. i picked up 3 of these used for my work and kept one at home. I knew one had issues and another had a burned out bulb and so on. I had a repair place to combine the two to make one good one. The repair man said that they had a real hard time keeping the color locked in alignment. It's not a physical alignment, its controlled by the board output and somehow the board can be adjusted. It was vague to me. After about a good couple of years of hard use the one at home is now doing the same. On one hand I want to fix it but I dont even have a plasma so I may go and spend $800-$1000 on a hi def DLP. At that price it won't be the best but it will rock this projector. that would be my advice rather than putting more money into this old model.
Aug 06, 2007 | Philips ProScreen 4600 Impact Multimedia...
RCA HD52W59 HDTV Projection Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
