Protection circuit trips a low audio output level MX-W50
Receiver/cd player/cassette recorder-player (Dual Drive)/AMP. Hitachi MX-W50
Regardless of program source the output protection circuit trips at any but very low sound level. If one channel is ''ballanced out'' the other can play at a higher level without tripping. Output heatsink is cool.
I'm unable to find a service or owner's manual or even a schematic.
  • stantonlw Nov 20, 2008
    Thanks,
    Went down that road. With only one speaker hooked up and the ballance shifted to the attached spkr, the trip level was about twice what it was with both spkrs connected. Exchanged spkrs with no change in results.
    As the heatsink is not getting warm, I surmise the shutdown is based on a current sense, possibloy in the stability feedback circuits of the power amp but without a schematic, I'm kinda stuck.
    L
  • mpsa95 Jan 03, 2009
    Yamaha-RX-V620 RDS.
    The problem is similar. Center, left and left-rear channels sometimes are sound with noise at low output level instead of the volume level is high. And sometimes they do not produce any sound at all. It seems to me, I have unfortunately shorted the output of the left-rear speaker and the problem is the result of it.
    If volume level adjusted to higher values the speakers produce defective sound, at low volume (<-60 db) level they are not sound at all.
    Disconnecting of any speakers not results in normal operation of connected ones. When I connect the "silent" speaker to properly-operating channel it results in good sound from the speaker. Connecting
    the good speaker to "silent" channel results in silence. So, I think that speakers and wires are OK, but some channels are not.
    How to solve the problem? Has anybody the service manual or schematic of the device? If you have one, please, send it or link on it to my e-mail: mpsa@list.ru.
    Scholar:
  • 146 Answers
When you unplug one speaker (from the back of the receiver) and the rec. works good, then the speaker that you unplugged is the bad one, or the wire that is hooked up to that speaker is bad. Repair the speaker or the wire.
Posted on Nov 19, 2008
  • Randy Sheppard Nov 20, 2008
    What happens when all of the speakers are not plugged in and you turn up the volume?
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
No sound output from turntable on sx-780 receiver
do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Dec 18, 2012 | Pioneer Sx 780 Stereo Receiver
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Set keeps shutting down .this amplifier shuts down in about 30 seconds after turning it on
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Jan 28, 2010 | Yamaha HTR-5850 Receiver
How to connect a record player to Pioneer
If there are no specific phono inputs, then a phono pre-amp must be purchased. These usually cost around $20. This pre-amp will boost the signal level to that of a CD player or tape deck so that either a tape input or aux input can be used. Once you have the pre-amp, just connect its output to an open input on the receiver.
Dan
Jan 12, 2010 | Audio Players & Recorders
Turn unit on, display flashes for 1 second, then
Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. If you didn't find anything, think again about what the problem might be (and maybe taking it to a repair shop) before going to the next step.
Plug it back in and power up again. Before the delayed speaker amp output clicks on, immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine). Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Nov 05, 2009 | Yamaha HTR-5850 Receiver
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Connect audio components for recording Cassette to CD
Try this since you do not supply model numbers. If your receiver and CD have digital audio connector (coaxil or fiber) hook the receiver output to the cd input.
If you do not, see if there is a spare set of RCA jacks for output. If not, just hook up the cd player in the cassette jacks-there is always a cassette in and out-and hook your cd player to an auxillary input or use the cd player input.
Remeber though, cassettes have inherently more noise than cd so your cds will not sound like a pre-packed cd.
Dec 22, 2007 | Sony SS-X90ED Main / Stereo Speaker
Questions
Swop the CDR into the tape outputs on the amp and use it just like the tape recorder you had hooked up. Also do a direct digital link to a CD player for digital copies.
Aug 18, 2007 | Teac CD-RW880 CD Player / Recorder
362 people viewed this question
 Grubhead
Grubhead
