Question about Diamond Audio TDX-10D4 Car Subwoofer
Subwoofer: diamond tdx10d4
I have a subwoofer which does not play any sound until i push the surround in a litle bit,once pushed and held bass stars playing,then if you let it go bass stops.plz is there a way to fix this problem.
  • 68 Answers
You could go back into the wiring systems and by past the button,.then put a toggle switch there so u can keep it on when u want or toggle it off to turn off the system
Posted on Nov 19, 2008
Windows vista wont let me select subwoofer
Try Control Panel > Sound and Audio Devices > Volume > Speaker Settings > Advance. Choose Speaker setup.
Aug 27, 2012 | Gateway GMAX 2100 Computer Speakers
Subwoofer makes cracking/tapping sound sound.
Could be a defective or burned out voice coil
Nov 16, 2017 | Audio Players & Recorders
My aiwa surround sound subwoofer is not working. I can here bass when I touch my finger to its cord however. Just isn't working when I play music.
Hi,You did not give make and model of your Receiver !!!
Was it working before or you have just connected it to the receiver..? All surround receivers have a surround Sound Setup procedure that either Activate or Deactivate the Subwoofer..So,pls check your Sound set up and speaker Connectiions on the back of Ampl?f?er.
If problem continues pls let me know with more detailed description.
Hope this helps! Take care and please Remember to rate/vote us
to continue for Helping out the Community :)
Thanks
Aug 21, 2011 | Audio Players & Recorders
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
Can i use my jensen jxp340 amp with my one 800watt 12" 4 ohm subwoofer?
Yes, technically you can, however you will be putting both your sub and your amp at risk. One of the worst things you can do to a sub is underpower it. The easiest way to explain it is n ot giving enough power to the sub leaves it starving for power. The motor structure ends up working too hard to try and move the cone properly and what happens is the sub will usually seize up rather than blowing out in the term you usually hear (ie, I had my system cranked up and I blew my subwoofer).
Secondly, in an attempt to get any real sound out of the under powered sub, you'll probably end up cranking the gain and bass boost on the amp which ends up overworking the amplifier quite a bit and can in turn lead to fried out amp chips, burnt up circuit boards etc.
Thirdly, by maxing the gain bass boost you're going to end sending a lot of distortion through your subwoofer in an attempt to get some decent bass. Distortion kills both subwoofers and speakers alike.
So to answer your question, yes you can hook up your subwoofer to that amp and yes, it will probably play for a while but I wouldn't recommend it. Look for a class d or mono block amp to push your sub as these will give you the most power and best heat dissipation. They are designed to push subwoofers specifically and you will get better sound and longer life out of your equipment. A good rule of thumb is look for an amp within 100-150 watts of both your RMS power handling and your Peak power. Remember, when it doubt, always go a little bigger on the amp side of the spectrum. It's easy to "tune down" an amp by having the gain and bass boost at a lower level (50%, 25% etc), than to turn 'em all the way up just to get some bass and end up prematurely blowing out your sub, amp or even worse, both.
Dec 01, 2010 | Jensen JXP340 Car Audio Amplifier
Subwoofer/Bass not working
I apologize if this question sounds offensive, but did you plug the power adapter in to an electrical outlet? When the power switch is on, do you get any LEDs or an audible thump or hiss from the subwoofer?
Oct 29, 2017 | JBL Creature 2.1 Computer Speakers
5.1 surround sound
Here is how you fix it. Its really easy actually take a look at your Subwoofer 99% of the time you can control two controls for your bass somewhere around the Subwoofer. If you raise the volume of your Subwoofer you'll get more bass. Try it and let me know how this works out for you alright.
Oct 03, 2008 | Audio Players & Recorders
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
Diamond Audio TDX-10D4 Car Subwoofer Logo
113 people viewed this question
Top Diamond Audio Car Audio & Video Experts
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
jeff5may32
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
