Question about Jet Equipment & Tools 577101 6 1/2 Hp 1 Phase Bench Grinder No.jbg - 6a
On off switch
How can i get a switch for the Jet DC 1200 dust collector
    Scholar:
  • 140 Answers
Can I disassemble an hp office jet e609n printer, to clean the inside
Wisdom says no. If you want to clean the paper path easily go to an office supply store and get printer cleaning paper. It is sticky on both sides and will remove paper dust from the pick up roller and all the other rollers inside. It will also clean any leftover bits of paper from jams. Any internal dust buildup will be cleaned too.
Oct 18, 2016 | HP Officejet 6000 E609N Inkjet Printer -...
Looking for dust collector Hitachi Vacuum Cleaner CV-BL16
Go to their website, look for your model and see if they have replacement parts.
Feb 18, 2015 | Vacuums
Sometimes it doesn't read a disc. It could be a good CD from the store
Erratic behaviour in CD players is mainly caused by 3 phenomena.
Worn out laser, dust and dirt on the laser lens, problem with the sled-motor.
When the laser is worn out, you get "no disc" all the time, as it is not able to find focus. The same happens with dirty lenses, but not always. Cleaning the lens is the solution. This is done with pure water using a cotton ear bud. NO alcohol or any other solvents may be used, as this might damage the lens coating, whereupon the unit is totally "screwed up." and has to be replaced.
When random problems like skipping and jumping appear, even with new discs, there is a problem with the sled motor/mechanism.
This mechanism "follows" the track on the disk.
A common failure here is caused by collector contamination from the sled motor. As is turns very slowly, there is no self-cleaning effect from it's collector.
Remedy: Take the motor out of the mechanism. It should be disconnected from any circuit in the player. Take a DC supply and make it spin for a FEW Seconds on 12-15V. Don't do it for a prolonged period as these motors are only ment for max 5V DC. By doing so, this cleans the collector and burns away the remainders of graphite located in between the collector sections. This graphite comes from the carbon brushes.
After reassembly of the sled mechanism, slighty lubricate the two sliding rods with silicone oil f.i.. Check for smooth movent all the way.
In general. Disassembly an reassembly of CD changers can be quite tricky. So take good care of the positions from gearweals, notches etc.
Aug 03, 2013 | RCA RP8065 5-Disc CD Changer
My dyson ball has no suction ... i turn it on and sounds normal for a few seconds then it sounds like it clogs then no suction but i checked the tubes theres nothing there...
Take off the dust collector , put the machine somehwere out in the open air and switch it on if the motor runs up to speed then the probelm is inside the dust collector and it is probably a blocked hepa filter
If the motor does not run clean with the dust collector removed then you need to remove the base plate and check for blockages there
Jan 25, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
Hi! I have a delta dust collector model 50-850 and electric motor has like this little starter or i dont know what you call it, that started to throw smoke out of it, i had used it since but i need to find...
Look for the part here. From your description of the problem it might be item 21 (switch box) or item 26 (capacitor). If it is the switch box there may be additional part numbers to be ordered.
Dec 03, 2009 | Delta 50 - 850A Dust Collector with 2...
Dust collector
dust collectors usually work off the motor via a fan. Either the fan is broken or the bag is blocked up.If the bag is too dirty inside you don't get any airflow through the bag which can stop it collecting. A good wash should do the trick
Aug 29, 2008 | Porter Cable 3" x 21" Electronic Variable...
Jet Equipment & Tools 577101 6 1/2 Hp 1 Phase Bench Grinder No.jbg - 6a Logo
155 people viewed this question
Top Jet Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
bob walter
bob walter
Level 1 Expert
Are you a Jet Grinder Expert? Answer questions, earn points and help others
