Question about Polaroid Televison & Video
No pictuer polaroid tda-03211c
Have sound and can change chanles but no picture
  • 4 Answers
My unit would come on and after a short time the picture would go to black I placed an small fan on the back of the unit the additional cooling worked butthe fan noise is distracting looking for a better solution
Posted on Nov 17, 2009
Polaroid tv model#tda-03211c i have sound but no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 19, 2015 | Polaroid Televison & Video
Is there any way to power the backlight on an lcd tv without changing caps. POLAROID (HEMROID) TDA-03211C
Double check your soldering and make sure caps went in correctly + and - wise.
If you found bad caps and replaced them your problem is likely on that board and another part or parts there are also bad.
May 16, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
My Polaroid TDA 3211c powers up, has sound but no picture comes on. What could be wrong?
That indicates a problem with loose inverters or the inverter board itself needing to be replaced.
Feb 05, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Hello, I have a Polaroid TDA-03211C. It came on fine but now I have only sound and no picture. I can change channels and adjust the volume, but I can not see a picture. HELP!
you have one or two bad capacitors in the power supply tha can shaped device will have a domed or puffed top where it vented the value is written on the side have someone replace them and you will be good to go
Dec 04, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a poaroid 32 in modle#tda-03211c the sound works but there is no picture
This not a solution but I am having the same problem with the same make and model of television.
Nov 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid tda-03211c no picture
I was just looking at my manual for mjne and there is a fuse behind the set in a small plastic box you might check it
Oct 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
How to set smart sound on polaroid tv model # tda-03211c
As far as I am aware, only Philips Magnavox has this option.
I did some searching and have yet to find this option for your tv. I will do further searching and let you know if I find anything different.
May 30, 2009 | Polaroid Televison & Video
Wat is a digital optica light in polaroid tda 03211c
It is an optical output for audio. It is used for high quality audio for surround sound systems etc.
Apr 06, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Televison & Video Logo
168 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
