Question about Mitsubishi VS-50705 50" Rear Projection Television
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
My Mitsubishi VS-50705 had some issues. I created a problem under the VS-40605. But Proton1000 gave me the fix right on by replacing some capacitors around the PIP part of the signal board that connects to the main board. I have the service manual and attempted to adjust using the service menu data the main picture/feed. But I can't get the color to come out correct. The red seems overpowering. The white is like being under a black light. It is overpowering. When the picture starts to fade out in a program to go to another frame the white and colors look better right before the frame changes. Again the PIP picture looks great. Now this set has the split screen. But it won't allow the same feed so the subfeed is black. I switch to the main with 3 little subfeeds scanning channels and they look great. I switch to the main with an adjustable size PIP subfeed and it looks great. I enter service menu adjustment and when I get to the VCJ sub function that brings up the split PIP screen then the subfeed seems fine. Do you think there is still other capacitors in the area I already serviced could still be bad. Or do I need to look into the PIP circuitry to see if the path of the IC is bad? Also any help on focus adjustment would be nice. I don't have a monochrome input so a lot of the service manual adjustments I can't do at this point. LOVE THIS SITE!!!!!
  • Jeff Thomas Dec 09, 2006
    The PIP portion on my VS7+ chassis is not a little board that connects to the "main board". You are thinking of the other models. Mine has the PIP IC chip built right into the "signal board" So I can't just do the easy "bypass". I've seen this advise twice now.
    Does anybody else have any solutions for the correct board and circuit type?
  • 65 Answers
Rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Posted on Dec 09, 2006
2 Suggested Answers
  • 1153 Answers
SOURCE: Mistubishi VS-50705 can't get color set and white overpowering.
Do you still have this problem?
Posted on Mar 10, 2008
My Mitsubishi VS-50705 is dark on screen, do I need to replace the bulbs to fix it? where to buy the bulbs? Thanks
There are no bulbs in this set. Only 3 crts red,blue and green. crts are probably going out. repair expense will exceed value due to age.
Dec 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
My tv won't turn on
OK BUDDY IM NOT A HOE FIRST OF ALL AND SECOND LERN TO SPEEK GOOF
Nov 17, 2009 | Mitsubishi VS-50705 50" Rear Projection...
VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
Jun 27, 2009 | Mitsubishi VS-50111 50" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50705
Maybe you have a problem with the Vertical out, and you need change it.
May 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Black horizontal bars and jumpy picture.
Yes . Some of these caps are in the secondary of the power supply and some are on the signal board around 5v and 7v supply lines on the signal board . The 5 & 7 are mounted on heat sinks and the caps are right around there .Generally either 2.2uf or 4.7uf or the 47uf . Good luck
Dec 19, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Intermittent vertical jitter.
What I've found is that not all models have a PIP module that is removable. Some of the models have a PIP IC (IC6P01). It's built into the signal board. You can't see it unless you remove the shield cover. There is also a plate cover on the underside of the signal board. It's soldered on. This information will help identify your particular model. I also have a built in PIP circuit. I repaired my set by replacing the following electrolytic capacitors. (C2P02 47mf 35v), (C2P03 100mf 16v), (C2P04 47mf 50v) (C2P05 100mf 16v) and (C2P08 100mf 16v). These capacitors are located on the right side of the signal board, where the signal board connects to the main board. They are located next to heat sinked voltage regulators, one of them being IC2P01 (9v IC regulator). I'm not sure which capacitor was the actual culprit, however it's been said that C2P05 fails a lot in these sets. Anyway, good luck with the repair. proton1000
Nov 17, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
