Question about Refrigerators
Recently bought a samsung rl38sbsw fridge freezer it worked or 24hour Then side got really warm is this normal?
    Problem Solver:
  • 19 Answers
New new code...
5a 01..
3F 32 37 03 D0 73 84 84...
C6 64 1D EF 47 5A 0E EF.......18.55PM
Posted on Nov 30, 2008
I have the same freezer and it's normal for the sides to be warm. I've had mine for over 3 years so yours is working fine.
Posted on Jan 03, 2009
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
I've got a Samsung Fridge (model RL34SCSW1, http://www.samsung.com/au/consumer/home-appliances/refrigerator/bottom-freezer/RL34SCSW1/XSA/index.idx?pagetype=prd_detail). Recently I switched it off for a...
The 15 sec burst sounds silly to me but you were right to let it settle for a while before starting although 45 deg should not harm the fridge at all. As for the heat on the sides if the unit is working well (cold enough in both sections and shutting on and off) then I would suggest it is fine. If the fridge is working hard the gas entering the condenser is up to 150 deg. F or more it can be very uncomfortable to touch even after travelling a distance to the sides of the unit.
Feb 26, 2011 | Samsung Refrigerators
Nothing to worry. Over heat due to non condensation. Keep the fridge 10 inches away from the wall. And clean the condenser coil by an air blower. Problem solved. O;K?
Feb 26, 2011 | Refrigerators
Side by side fridge freezer warm on upper levels
the cold coil is in the freezer side at the bottom . the fan moves the air over coil . ck that your fan in freezer is working . mm
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Sep 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
349 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
