Question about HP LaserJet 4100 Printer
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller and the fuser. Strange problem , when i let the paper out treu the back cover ,its oke. The gears seams to be oke. thanks Bas
  • Anonymous Apr 11, 2009
    paper jam
  • 66 Answers
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Posted on Dec 18, 2008
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
Laserjet 4100 taking in extra paper
Picking up more than one sheet of paper indicates the pickup rollers and separation pad is worn and they will need to be replaced. These parts work together to pickup and separate the paper from the paper tray and when they get slick the rollers allow more than one sheet to enter the printer which causes a paper jam and misfeed errors. The rollers and separation pad come in a kit and is user installable, no need to pay big money for a repair shop to do it for you. The kit RK-4100 is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=259
Mar 28, 2013 | HP LaserJet 4100n Printer
When powering up the hp laserjet 4100n printer, it makes loud noise, and also states paper jam error and says to open top cover but there is no jam
Thank you for contacting FixYa with your printer inquiry.
yror2cow4ujehy7na20urcensmog20sjgurjxm4tuhbyg-zg2zbskniapisbqy8nf1kewpzeogdnflqy9ha2khbu5k8s2c19uem0r7dwagust35jfphz810nyjeqc2hldzxft7w1k4xvjdgbtu1g=s90-cRB1-8974-000, 4000/4050/4100/4500/4550 Separation Roller" />
HP Laser Jet 4100 Loud noises and paper jams
This error happens when the Pickup Roller/Clutch wears out. It's quite common and easy to repair. Purchase and install Roller/Clutch Part Number RB1-8974-000CN
Action: Do a Google search on the following link [hp laserjet 4100 + Roller/Clutch problems ] and you will locate numerous vender's of this part number item.
It's easy to install. Just unplug the power cord and disconnect the network cable, then set the printer on its back
and remove tray number two. The roller clutch will be visible. It has a pinch release that allows you to slide it off
the shaft and re-install the new one. It should snap in place. Right the printer then reconnect network cable and power cord and power back up. Function should be restored.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Mar 28, 2011 | HP LaserJet 4100n Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
I AM USING HP LASERJET PRINTER 2300dn and im experiencing jam, what is wrong with the tray?
I think it not the paper tray. It is the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
Jan 07, 2011 | HP LaserJet 2300dn Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
HP Laserjet 4100 jams after about 50 print jobs
most typical jams are caused by bad pickup roller or separation pad. When you pull out the paper tray, and look inside the printer above the tray area, there's a roller that is held on with a little clip in the center of the roller. Pinch that clip to take the roller out and clean with soap and water. do not use alcohol based cleaners, they dry the rubber up and shorten the life span drastically. The separation pad should be right at the front of the paper tray, clean that also. If your printer keeps jamming after that, you may have some more serious like a fuser going bad.
Oct 05, 2009 | HP LaserJet 4100 Printer
HP LaserJet M3027 indicates paper jam but there isn't a jam.
if you are getting a paper jam message but you can not find paper any where in the printer the first thing that you want to do is clean the pickup roller in the paper tray. the roller is located on the top of the cavity that the paper tray is installed in.
Mar 11, 2009 | HP LaserJet M3027 MFP All-In-One Printer
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Jan 03, 2009 | HP LaserJet 5000n Printer
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Rgds
S88
Dec 18, 2008 | HP LaserJet 4100 Printer
HP LaserJet 4100 Printer Logo
586 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
