Question about Samsung SyncMaster 914V 19" Flat Panel LCD Monitor
New laptop images are overfilling the Samsung screen
I have a new HP Compaq 2230s laptop. The image on my SyncMaster 914v now is about 10% wider than the screen. I have to use a curser to point to the right and left to read the whole screen in-but the image is fully on the laptop screen--but smaller than I can read.
Maybe the format of the new HP screen is wider than my IBM Thinkpad, but the vertical and horizontal controls did not seem to do anything to solve for the problem
5 Suggested Answers
josiahb
  • 25 Answers
SOURCE: my samsung syncmaster 914v isnt working
Ok, a few basic things to check/try.
  1. What colour is the power LED, does it change when the screen flickers?
  2. Is the power cable firmly seated.
  3. Is the monitor cable firmly seated.
  4. Try another power lead.
  5. Take a look at the plugs on the monitor lead, does it look like there are any bent/broken pins.
  6. Again, try another monitor lead.
  7. Try connecting the monitor to another pc.
If none of these have any effect, you'll need to take it in somewhere to get it looked at.
Posted on Feb 25, 2010
budmrtn
  • 11361 Answers
SOURCE: samsung syncmaster 914v monitor problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
drunknmonkey
  • 136 Answers
SOURCE: What adaptor do i need to connect a new Mac Mini
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Posted on Jan 20, 2011
budmrtn
  • 11361 Answers
SOURCE: Hello my syncmaster 914v is
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 25, 2011
My webcam is not on my device manager, not even showing Imaging devices any more.
first thing i would think is it worn out from opening and closing lid
requires looking under keyboard let me know if want to know how or if you want to try replacement
Mar 03, 2013 | HP Compaq Business Notebook 2230s
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
Such as:
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My samsung syncmaster 914v isnt working when i plug it in and turn it on all it does is flicker every like 10 seconds
Feb 25, 2010 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
Samsung 914v 19" LCD pixels went out
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 31, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Connecting a Compaq nx6310 laptop to a bigger monitor
Should be Function Key and F4 (or a similar FKEY will show a monitor screen)
Press 1x to push image to ext. monitor
Press 2x to have dual display
Push 3x to just have laptop screen
Dec 08, 2008 | HP Compaq WF1907 Monitor
Connecting Toshiba notebook to Samsung LCD TV - small image only
because you have added a new monitor, you have to go into your graphics settings and set the screen resoloution to a setting your comfortable with
hope this helps
regards
Nov 20, 2008 | Computers & Internet
Samsung SyncMaster 914V 19" Flat Panel LCD Monitor Logo
52 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
