Question about HP Computers & Internet
HP Compaq nx7300. Pin has broken off from the power cord supply. Mains input cord now won't work as part of pin is possibly stuck inside. Took to original supplier who quoted £220 to replace entire motherboard and power supply. This can't be only option?
  • HP Master
  • 4,806 Answers
Absoloutly not!!!!! if the pin has broken in the external power cord and not inside the PC itself then all you have to do is replace the PSU ( power supply unit ) and the lead, this should cost you no more than £35 and its easy to replace yourself
Posted on Nov 18, 2008
My new laptop battery is not charging
Maybe the battery is bad. Just because it's new does not mean it will work.
Does your laptop power on and work with the AC Adapter and Power Cord? If not, that is why your battery is not charging. You need a New AC Adapter & Power Cord or the DC Jack where the Power Cord plugs into the laptop is bad or broken.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 15, 2012 | HP Compaq nx7300 Notebook
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
Hp compaq nx7300 laptop problems are any word type give wrong input command. pls solve my problems? thanks & regards ravi ..
hi there, i was replaced my hp Compaq nx7300 laptop's keyboard but its not working what else could be wrong can you give any hints on mother board repair b caz iam also hard ware engineer
Mar 23, 2011 | HP Compaq NX7300 (413554-B31) Keyboard
What is the power input voltage required to operate the phonic 1805x audio mixer? is this an AC, or DC input? unit missing power supply and needs to be bench tested for possible future use. no manual...
i have seen the manual. most mixers use ac mains supply with smps inside with +48V for phantom and ur mixer is one of those. u will see a three pin mains connector at the back. but phonic made these mixers for different countries. for us/canada 110~120Vac/60Hz - for uk/australia  230~240Vac/50Hz, europe/ asia 220~230Vac/50Hz.
Look for these or a voltage selector near the power input terminal. if u do not find any of these one sure way of finding which mains supply u should use is to open the case and look at the biggest rectifier filter capacitor on the smps board. 110~120V supply will have capacitors working voltage around 250Vdc and for the others around 400Vdc working voltage. (eg 1000uF, 250V or 1000uF, 400V)
so depending on the DC working voltage of the filter capacitor and country u either step up or step down the mains supply.
18Vac supply will never work.!
the rated mains voltage sometimes are printed on the smps board itself. Hope this helps.
Mar 13, 2010 | Electronics - Others
I have HP Compaq nx7300. no power, no charging
Most power supplied in HP machines are not very good. You will need a new one. If you have a differant cord try that first. If it is bad then order one. they can be obtained for under 50.00 US.
Oct 31, 2009 | HP Computers & Internet
Enternal power supply unit for a hp compaq nx7300
The part numbers for power supplies for your PC can be found HERE.
Mar 10, 2009 | HP Compaq nx7300 Notebook PC
The pin that the power cord goes into has broken off
Is the cord broken in the computer, or the monitor or the pin broken and stuck in the machine? If it is in a desktop it goes into the power supply. Which you can change the whole power supply fairly cheap. that is if it in a desk top computer. 4 screws, 4 or 5 connectors and ta da new power supply, All you need is readings off power supply such as wattage. Good luck
Mar 10, 2009 | Acer TravelMate 2480 Notebook
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
