Question about Krups Small Appliances Espresso Machine
Krups Pro Grinder Brewer - water leak
My Krups leaks water from the bottom of the main housing unit- just a small amount that does not effect the brew but does leave a puddle under the unit daily. Also does a lot of hissing throughout the brewing process which I can live with. I mention this in case it might be connected to leaky problem. This unit is less than one year old and started leaking only recently. Thanks!
  • Anonymous Dec 04, 2008
    Same for me... Water comes threw "rubber feet" on the bottom - weird!
    ThereĀ“s always lot of water under the machine, which cannot be good for the table at least
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
SOURCE: My Krups won't brew
had the same type of problem with a hair dryer once. A thermal interrupter- I called it a planned obsolescence gizmo- died. I bypassed it with a silver wire soldered in and the hair dryer ran well until another part died years later!! Sailorb
Posted on Sep 14, 2008
cactus bob
  • 267 Answers
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Posted on Mar 01, 2009
SOURCE: One cup brewer, says it is brewing, but the
If the brewer heats the water but it doen not dispense this is probably because air is trapped in the tubing of the water system.
To solve, use as air compresser with minimum pressure (20-25 psi) and force air through the system using an air nozzle that is long enough to reach into the hole into the area where you fill the water. Place your hand under the dispenser and ensure you can feel the air from the compressor coming through.
Once you clean out the lines, you should be good to go.
We have had our coffee maker sitting on our shelf "broken" for months now. We tried this last ditch effort before tossing the machine in the trash and low and behold it worked! :)
Posted on Apr 05, 2009
SOURCE: Leaks water in the counter.
I fixed mine for 25p... you need to take the back off, and the tank holder out (2 screws each). There is a very thin pipe that comes out the pump - that is the leak.
Unclip the little clip and pull out the pipe and fish out the black o-ring out the hole.
Buy a new o-ring and put back together... no leaks =)
Posted on Nov 15, 2009
How do I fix a leaking Bunn Coffeemaker model NHBX-B?
This is a home model pour over. Overfilling is the most common cause of leakage as there is no plumbed in water line. You should only pour in the amount indicated on the decanter. If it is overflowing, check if you have the right decanter as someone may have used an old pot from a larger brewer. Say there was a 12 cup pot around and now you have a 10 cup brewer.
* carefully pour water to the inner fill line. You will probably see a ledge or spill off hole on the inside of the fill tank. Some units will spill out the back, others may spill back into the drip funnel. Note at what point you get near the spill level and note how much is left in the decanter. The amount left is your over flow.
* If you want more accuracy then use a measuring cup and count how many cups are needed to fill the brewer.
* Unplug any brewer that has water coming from the base. Dry up the area and drain the brewer. Dry off and let sit to completely dry out. Refill, note any leaks? If okay then plug in and brew as normal.
* still having problems? Contact your vendor for service.,
Aloha, ukeboy57
Jun 30, 2015 | Bunn NHB Coffee Maker
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Leaking water
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Water leaking while the brewer just sits there? Leak in the tank. Call for service.
* water leaks only while pouring? Then your pouring to fast. Wait for the water to drop before pouring in more. If it still leaks even while pouring slowly then there is a leak in the fill tray. Call for service.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Jan 12, 2014 | Bunn GRX-B
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
How can the length of the garden hose effect the amount of work done ?
Digital Satellite Coffee Brew Centers Model: BC302E-IT Twin
The Operator's Manual for your product can be found here:
http://www.grindmaster.com/docs/Ni90A-BC-IT-MAN.pdf
WATER HOOK UP
The National Sanitation Foundation (NSF) requires the following for NSF approved installation:
1. A quick disconnect water connection or enough extra coiled tubing (at least 2x the depth of the unit) so that the Brewer can be moved for cleaning underneath.
2. An approved flow-back prevention device such as a double check valve to be installed between Brewer and water supply.
WATER CONNECTION
The Brewer comes equipped with a ¼ inch compression water inlet fitting located in the back. Use a ¼ inch copper tubing to connect the Brewer to a cold water supply. Water pressure should be: 20 PSI min. to 90 PSI max. An external shut-off valve and a water filtering system with a charcoal filter are highly recommended. Turn water supply on and check for leaks at the water inlet connections, tighten compression fitting if necessary.
Hook-up using a garden hose would not be recommended; if the hose is too long you may not meet the minimum required pressure and will have difficulty filling the machine.
Feb 16, 2011 | Cecilware Coffee Brew Center wWater Tap...
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Nov 11, 2009 | Bunn VPS Coffee Maker
We have a Krups KP1010 Pod Brewing machine. The brew button is stuck and is blinking, but will not brew coffee. How can I reset?
For those of you having problems with your KRUPS KP1010 Pod brewer stopping brewing in mid-cycle and then having the blue led power light blink rapidly, I have found the cause of the problem as well as a solution.
I have a Krups KP1010 pod brewer at home that is nearly 2 years old and has NEVER had a problem. Having enjoyed it’s continued great performance, when a small group (8 people) of people in my office decided to go "POD", we pooled our money to purchase the Krups.
After 8 months of moderate, not heavy, use, this problem developed. It got worse and worse, so bad that it would stop almost instantly after pressing the brew button. Sometimes it would work as normal, and other times, we found that if you applied pressure to the top lid, it would work completely.
This started me thinking that there must be a sensor switch inside to detect when the lid is open. This suspicion was backed up by the fact that when the Pod brewer was ON, but IDEL, if you open the lid, the blue light would and should blink.
Here is what I did to fix it.
If you are at all handy with taking things apart and making small minor repairs, this problem can be easily fixed rather quickly.
There is a total of 8 screws to remove. Four are located at the bottom of the unit and are the same size. Two more are located under the water tank reservoir, so you will have to remove the water tank to access them. These two screws are the same size at the four that you removed from the bottom of the unit. The last two screws are located at the top of the tank, BEHIND the lid, but can easily be seen when you remove the water tank. Turn the KP1010 around so that the tank is facing you. When you have the tank removed, look at the top area of the body of the pod brewer. These are the last two screws that you will have to remove. They are NOT the same size as the other six, and you will likely need a smaller jewelers sized Philips screw driver to remove them.
Once you get the back of the unit off, with the water tank side of the brewer facing you (coffee pod area facing AWAY from you), look in the upper right corner. Unlock the latch at the front of the brewer. Now while looking in through the back water tank area, in the upper right corner, gently raise and lower the brewer lid. You will notice that there is a LID SENSOR SWITCH. The switch is defective and, like a washing machine, when the lid is OPENED, the switch cuts the circuit (power) to the brewer, the same as when the washing machine stops when you open the lid.
The Fix: While Pod brewer is UNPLUGGED, gently grasp one of the two connector wires attached to the lid sensor switch. BE SURE TO GRAB IT FROM THE METAL CONNECTOR AND NOT THE BLACK WIRE ITSELF AS YOU MAY PULL THE WIRE AWAY FROM THE METAL CONNECTOR AND WHILE IT IS STILL REPAIRABLE AT THIS POINT, IT WILL BE MUCH MORE TIME AND SKILL CONSUMING.
Once you have removed the wire and it’s metal connector from the lid sensor switch, repeat this process with the OTHER black wire connected to the lid sensor switch.
(I tested this fix by at FIRST using basic tape) The fix for bypassing the lid sensor switch is to connect both black wires together. I initially used basic tape to ensure that my suspected cause of this problem would be fixed by my suspected solution. I then brewed 3 tanks of water back to back and the "stop brewing, rapidly flashing blue light" problem NEVER appeared. FIXED!
Now to be a bit more professional about it……… I removed the tape and soldered the metal connectors of both black wires together, and then wrapped with electrical tape. You COULD just wrap them together snugly with electrical tape if your NOT into soldering, but for the best, most secure connection, SOLDERING is the best option as there is no chance of vibration causing the black wire metal contacts from intermittently losing contact with each other. Again, if you are un-comfortable with soldering, at least try wrapping the wires snugly together with electrical tape.
Today our Krups KP1010 brewed flawlessly all day. The ONE downside to consider in this procedure is that now after having this "fix" performed, should you leave the lid of the brewer OPEN and start a brew cycle, the brewer WILL operate and shoot hot water & steam out everywhere. However, for those of you that own this brewer, you should know that having the lid open nearly completely obstructs you from easily reaching the brew button AND, what moron would leave the lid open and try to make coffee? If someone does that, they DESERVE to get burned!!
Best of Luck!!
Ed
May 08, 2008 | Krups KP1010 2-Cup Coffee Maker
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Water leaking from coffee dispenser
Hei dory may be this can be helpful.Inside the machine take out the brewing group on the back panel there is asmall metal piston with 2 small orange rubber o ring.Try to replace that(is not easy since the position)were the o ring are locate is very unconfortable but is something i believe you can do it.That one is the main connector between the inside and the conjunction with your brewing group.
Good Luck
Sep 09, 2007 | Saeco Incanto Classic Espresso Machine
Krups Small Appliances Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
