Question about Estate TEDS840JQ Electric Dryer
Estate drye by Whirlpool
I bought a heavy duty Estate dryer made by Whirlpool 3 years ago. Its been in storage for a year. It won't dry. It's like the air is warm, not hot. Is there a replaceabe thermostate in a dryer? I need to fix this if at all possible. I've been unemployed for 7 months and can't afford o replace an almost new dryer. Any suggestions?
  • 5,911 Answers
The number one cause of insufficient heat problems with dryers is poor air flow. The first thing you need to do BEFORE assuming you have any defective components is to do a full inspection of the dyer to ensure it is not clogged anywhere. The easiest way to determine if you have a dryer clog is to leave the vent hose removed from the back of the dryer and attempt to dry a load. The air flow leaving the dryer should be forceful and about 140 degrees F. If the air flow is weak, you more than likely have a clog in the air blower assembly INTERNAL to your dryer. If the air flow is normal and warm as it is should be, you may have a clog in the vent ducting EXTERNAL to the dryer. This would be from where the ducting leaves the dryer to where it exits your home. If you have a vent line that runs through and attic or crawl space, they are notorious for clogging. If you haven't had the ducting cleaned or inspected recently, now would be a good time. You should also be using the semi-rigid (metal type) ducting. It resists crushing, kinking, is heat resistant, and resists rodents chewing through it. Another concern I have is that you mentioned the dryer was in storage. It is common for rodents to build nests inside the blower fan housing area and clog the dryer. Since you mentioned your dryer is getting warm, but not drying like it should, tells me the heating element is working. You may be right and you could have an operating thermostat that is failing and not allowing the heating element to stay on long enough to heat properly. However, I would recommend you inspect the dryer thoroughly first to rule out poor ventilation. The following link expains some of what I've mentioned in greater detail:
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope you find this information helpful. Let me know if you require further assistance.
Posted on Nov 18, 2008
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
How do you change a dryer belt
That is the same model dryer I bought for my parents eight years ago. You will have to contact Whirlpool for a repair guide.
Apr 22, 2012 | Estate TEDS840JQ Electric Dryer
Whirlpool estate electric dryer takes three full cycles to dry. Not sure if it is the heating element or the thermal fuse? This dryer is a 1/3 HP motor large capacity, heavy duty dryer.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 19, 2011 | Whirlpool Dryers
3 BATH TOWELS AND ONE HAND TOWEL WERE NOT DRY AFTER 60 MINUTES IN DRYER . THIS HAS BEEN A PROBLEM SINCE WE BOUGHT DRYER IN MAY. A LOAD OF UNDERWEAR, T SHIRTS AND SWEAT SOCKS ALSO WILL NOT DRY IN AN HOUR...
HI,
If the unit is less than a year, you problem is a restricted vent system and not in the unit either. A simple test would be disconnect the vent from the back of the unit, run the dryer. If your clothes dry faster, your problem is in the vent system. If no improvement, problem is in the dryer. Get back to me and let me know how this goes.
Thanks
Aug 09, 2011 | Maytag MDG2706A Gas Dryer
Replaced lid switch a year ago, and the heavy duty cycle works fine. However, the permanent press/delicate and normal cycles do not work (tub just keeps filling/emptying water). My research indicates that...
I agree, it is most likely a timer problem. Possibly "rust" build-up.
See the Whirlpool / Kenmore Service manual for top load, direct drive washer for troubleshooting and diagnostics procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 18, 2010 | Kenmore 24032\24036 Top Load Washer
Does not dry clothes
If its not heating up correctly you could have a bad thermostat, blocked up vent or dirty lint screen, or possible the coils that go near the ignitor need replacing.
Sep 21, 2009 | Dryers
My whirlpool duet dryer is only 4 years old and it does not dry the clothes completely, even when it is on Heavy Duty. Only way it dries the clothes is if I run it through 2 cycles.
Check to see that the lint filter and exhaust duct are clear all the way to the outlet. If the moist hot air is not being exhausted the clothes will not dry. If the vent path is clear and you are using auto-dry the sensor may be at fault.
Aug 13, 2009 | Dryers
I have model # eed4300tq0 it takes 3 times longer to dry than it use to. it use to dry in one cycle on high heat,now i have to use high heat 3 times to get completely dry. dryer is only 1 and a half years...
Blocked vent hose . Disconnect the hose from the dryer and dry a load . If dryes ok , check the vent hose and vent . Make sure there is good air blowing out the back .
Aug 08, 2009 | Estate TGDS840JQ Gas Dryer
Estate TEDS840JQ Electric Dryer Logo
103 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
